Best free tool for Geometry creation
Old   October 4, 2012, 07:03
Default Best free tool for Geometry creation
M Mallikarjuna Reddy
mmkr825 is on a distinguished road
Hi Foamers,
I am using OF 2.1.1 version and i wish to create very complex geometry. By using polyMesh (BlockMeshDict) utility it is taking too much time.
Please suggest me the best free tool for geometry creation and how get that tool.
Thanks
Regards
Mallikarjuna
mmkr825 is offline   Reply With Quote
Old   October 4, 2012, 09:13
Julien de Charentenay
julien.decharentenay is on a distinguished road
Send a message via Skype™ to julien.decharentenay
Hi Mallikarjuna,
There are a number of free tools that you could use. Most are likely to rely on snappyHexMesh to automate the mesh creation. SnappyHexMesh essentially takes a STL representation of the geometry you are trying to mesh.
The following tools have some level of integration with openFoam (i.e they are likely to export openfoam cases):
- Discretizer;
- EnGrid;
- Salome.
Julien
julien.decharentenay is offline   Reply With Quote
Old   October 4, 2012, 09:23
Hi Julien de Charentenay,
Thanks very much for super fast reply. Among Discretizer: EnGrid; Salome, Which one is more accurate and easy (user friendly)for the fresher. Please suggest me which version need to be installed for the good accuracy.
Thanks
Regards
Mallikarjuna
Old   October 4, 2012, 20:00
Hi Mallikarjuna,
My knowledge only extends to their existence. I have used them a little with various degrees of success, but not sufficiently to provide advice on how accurate/easy they are.
I forgot to mention gmsh - it would generate a tetrahedral mesh - in a similar fashion to Salome.
Julien
Old   October 5, 2012, 01:47
Hi Julien
Thanks a lot for your reply. I'll go according to your suggestion. Is there any tutorial which gives the step by step procedure for the installation of salome ?. If it exists, please send me the link.
Thanks
Regards
Mallikarjuna
Old   October 5, 2012, 03:16
Karl-Johan Nogenmyr
kalle is on a distinguished road
If you want to stick with blockMesh you might consider this tool:
http://openfoamwiki.net/index.php/Contrib/SwiftBlock
http://www.cfd-online.com/Forums/ope...tml#post383232
K
Sorry for the commercial
kalle is offline   Reply With Quote
Old   October 5, 2012, 04:37
Jan
SirWombat is on a distinguished road
Send a message via Skype™ to SirWombat
for complex geometries i normally use a rectangular background mesh created by blockmesh and snappyHexMesh with that complex geometry as STL file. Whether this mesh is inside or outside of the geometry can be selected within snappyHexMesh.
The advantage ist that the geometry can be created by your favorite 3D-CAD program as long as it can export to STL or OBJ files.
Have a look at this: http://openfoamwiki.net/index.php/SnappyHexMesh
~~~_/)~~~
SirWombat is offline   Reply With Quote
Old   October 5, 2012, 05:58
Hi Sirwombat,
Thanks for your information. I'll go through your suggestion.
Thanks
Regards
Mallikarjuna
Old   October 7, 2012, 06:58
Martin
latvietis is on a distinguished road
It actually depends from what you want to model. Firstly, I tried blockMesh, but the problem was that it simply doesn't allow to create internal physical boundaries that is really needed for some problems.
I found snappy too hard for beginner, but it seems worth to try. I prefer Gmsh.
Martin
latvietis is offline   Reply With Quote
Old   October 7, 2012, 14:21
Elvis
elvis will become famous soon enough
there is in overview of
Openfoam GUIs
Calculix has also the Option to Export to OF
elvis is offline   Reply With Quote
Old   October 8, 2012, 02:20
Hi Elvis,
Thanks for the quick reply. Among open sources which one is easy for freshers. I am dealing with pipe, channel flows.
Thanks
Regards
Mallikarjuna
Old   October 8, 2012, 03:25
Elvis
my answer is subjective, because the way I work might not be the right one for you.
For pipes/channel I think discretizer (to model directly in that tool) or engrid (models made with blender) could be useful tools.
Old   October 8, 2012, 03:53
Hi Elvis,
Thanks for reply. I'll go through according to your suggestion.
I have one more doubt not related to this thread.
i developed my own solver for predicting velocity profile(U) and particle concentration profile(T) for suspension flow (fluid+particles). And in my momentum equation, the viscosity is not constant, it is function of particle volume fraction(T).
And i written the momentum equation as follows:
tmp<fvVectorMatrix> UEqn
fvm::div(phi, U)
- fvm::laplacian(nu*pow(1-T/0.68,-1.82), U)
UEqn().relax();
sources.constrain(UEqn());
solve(UEqn() == -fvc::grad(p));
where T is the particle volume fraction (dimensionless scalar field).
For predicting particle volume fraction(T), the governing equation written as:
solve
fvm::div(phi, T)
- fvm::laplacian(0.62*1.82*pow(a,2)*g*pow(T,2)*pow(0 .68-T,-1), T)
- fvm::laplacian(0.41*pow(a,2)*g*T, T)
fvc::laplacian(0.41*pow(a,2)*T*T, g)
Where g = local shear rate
= sqrt(2*E:E)
= 1.4142*sqrt(magSqr(symm(fvc::grad(U))))
when i run my case (simple channel flow) by using my solver, at initial conditions it is giving the following error.
error message:-
Create time
Create mesh for time = 0
Reading transportProperties
Reading field p
Reading field U
Reading field T
No field sources present
SIMPLE: convergence criteria
field p tolerance 0.01
field U tolerance 0.001
field T tolerance 1e-05
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 4.00548e-06, No Iterations 4
DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
#0 Foam::errorprintStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 FoamDILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#4 FoamDILUPreconditionerDILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#5 Foam::lduMatrixpreconditioner::addasymMatrixCons tructorToTable<FoamDILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#6 Foam::lduMatrixpreconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#7 FoamPBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#8 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libfiniteVolume.so"
#9 Foam::fvMatrix<double>::solve() in "/home/malli_reddy/OpenFOAM/malli_reddy-2.1.1/platforms/linuxGccDPOpt/bin/myDiffusiveFoam"
#11 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
#12
Floating point exception
malli_reddy@ubuntu:~/OpenFOAM/malli_reddy-2.1.1/PROJECT/myDiffusive$
But when i give good initial guess (by running the same case by using another solver in which coefficients are constants), then the case is running and giving good results.
By the same i extended to complicated geometries (like Y-shaped channels.), even i am giving the good initial guess, the case giving the same above error.
And i used SIMPLE scheme for pressure velocity coupling.
could you please suggest me what is the error and how to rectify it.
thank you.
cheers
Mallikarjuna
creation of mesh for boundary layer in Fluent Meshing Tool fferroni FLUENT 2 December 8, 2011 06:05
New Free tool for Thermo-fluid analysis Hamish Main CFD Forum 0 November 8, 2011 14:47
CFX 4.4 New free surface option Viatcheslav Anissimov CFX 0 April 3, 2002 07:27
Variable Density - Free Surface with FIDAP Vitaliy Pavlyk FLUENT 7 May 2, 2000 16:56
