October 3, 2012, 06:27 |
Problem with parallel run
Stefano
Rep Power: 17 |
Hi foamers,
I have this problem. During a parallel run, a variable is not calculated. How can I fix this problem? Please help!!!! Thank you Stefano |
October 3, 2012, 06:39 |
Bernhard
Rep Power: 22 |
Can you be more specific?
October 3, 2012, 06:48 |
Stefano
Rep Power: 17 |
I'm trying to use FSI solver modified and i have the variable "motionU" (used for moving the fluid mesh) which is not calculated when i run a parallel simulation. The same simulation, if launched in single processor, calculates "motionU" correctly.
Why? What should I do to fix it? |
area does not match neighbour by ... % -- possible face ordering problem | St.Pacholak | OpenFOAM | 11 | September 4, 2024 04:28 |
First Parallel Run - need some help | Gian Maria | OpenFOAM | 3 | June 17, 2011 12:08 |
nonNewtonianIcoFoam - problem with parallel run | chris_sev | OpenFOAM Bugs | 4 | April 1, 2009 09:13 |
Parallel run with engineFoam | francesco | OpenFOAM Bugs | 1 | November 25, 2008 07:06 |
Problem on Parallel Run Setup | Hamidur Rahman | CFX | 0 | September 23, 2007 17:11 |
