Running an airfoil case
Old   October 2, 2012, 10:01
Default Running an airfoil case
Simone
batta31 is on a distinguished road
Hi to everyone,
I want to run a simulation over a 2D airfoil with the following hypothesis:
It's a 2D, steady-state, laminar, incompressible simulation so I've modified the simpleFoam solver, switching the turbulence to "off". I've also build a "C mesh" over the airfoil.
What I'm now troubling with are the boundary conditions: I thought that the most appropriate BCs would be:
- freestream BC for velocity (everywhere except on the foil, where I've put the no slip condition);
-freestreamPressure for the pressure;
openFoam doesn't like these condition, I think because there isn't a "reference value" for the pressure, but also USING a reference value for the pressure, the simulation "explode" and doesn't converge to any reasonable result.
This is my problem. Has anyone any suggestion?
Thanks in advance
Simone
batta31 is offline   Reply With Quote
Old   October 2, 2012, 10:43
colinB is on a distinguished road
Why don't you use fixed value and zero Gradient?
With these two you should be able to define your system
sufficiently for both velocity and pressure.
freestream doesn't make any sense since you know your velocity
in most parts of your domain
regards
colinB is offline   Reply With Quote
Old   October 2, 2012, 11:52
Simone
So you're suggesting:
-U fixedValue (equal to zero) over the airfoil for the no-slip condition;
-U fixedValue (different from zero and equal to my desired velocity) over the other patches;
-p zeroGradient on every patch except inside the domain where i can fix an arbitrary value?
Thanks again Colin
Old   October 3, 2012, 10:41
not exactly:
all values you know you should specify with fixed value.
That includes the velocity at the inlet and in the internal field
all values you don't know you assign with zero Gradient
that includes all pressure values (outlet foil inlet)
and velocity at the outlet.
The velocity on the foil depends on whether you want to take
into account friction or not
If so set it to zero if not use slip
Old   October 3, 2012, 11:23
Simone
This is the error I get if I use zeroGradient for every pressure patch:
FOAM FATAL IO ERROR:
Unable to set reference cell for field p
Please supply either pRefCell or pRefPoint
Because of that I had thought to set a reference value in one patch. Is there another solution to fix this problem?
Old   October 5, 2012, 04:24
maybe this helps:
what is the internal field of your p file?
I set it to uniform 0
Old   October 5, 2012, 07:12
Simone
Me too!
Here's the full list of my patches and relative BC for P:
internalField uniform 0;
boundaryField
inlet
type fixedValue;
value uniform 0;
outlet
type zeroGradient;
top
type zeroGradient;
bottom
type zeroGradient;
foil
type zeroGradient;
front
type empty;
back
type empty;
if instead of inlet BC set as fixedValue I would set it as zeroGradient I'll obtain that error.
Old   October 5, 2012, 08:04
I found an old p file from my graduation thesis:
(at that time I used OF 1.7.1):
dimensions      [0 2 -2 0 0 0 0];
boundaryField
    wInlet
        type            zeroGradient;
    outlet
        type            zeroGradient;
    foil
        type            zeroGradient;
    frontAndBack
        type            empty;
and this is how my fvSolution file looked like:
solvers
    p
        solver          GAMG;
        tolerance       1e-07;
        relTol          0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    U
        solver          smoothSolver;
        nSweeps         2;
        tolerance       1e-08;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 4;
    pRefCell        0;
    pRefValue       0;
relaxationFactors
    default         0;
    p               0.3;
    U               0.7;
    nuTilda         0.7;
note that there is a reference cell defined, of which I wasn't aware
anymore.
This would make your fixedValue definition at the inlet for the pressure
obsolete, which I think is better, for you don't know,
what pressure values there actually are
Further I have to mention, that I didn't use a top and bottom patch
for my flow was inclined!
Finally I would suggest you to collect all patches with the same
properties in one patch (e.g. frontAndBack instead of separate patches
front, back -> simply collect the node numbers in the blockMeshDict in
one patch definition), this improves readability.
Old   October 7, 2012, 12:27
saeid oqaz
saeid.oqaz is on a distinguished road
hi Simone & colin
i working on same project but in 3D. i have 2 question.
what is the internal field of your U file? is the freestream velocity?
and colin you what solver use for this case? and in fvsolution dic GAMG relevant for P. i use CG.
can u attach fvSchemes file & B.C file for U?
saeid.oqaz is offline   Reply With Quote
Old   October 8, 2012, 03:38
Simone
@Colin:
I try to run your mesh with "zeroGradient" everywhere on "my" solver with this parameters for p:
solvers
p
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.01;
It runs and doesn't create problems! So I can't still understand where the problem is.
@Saeid: For U i used fixedValue everywhere except on the outlet patch where i put zero gradient. For the solver I can tell you that, since my simulation is steady, I used simpleFoam solver.
Old   October 16, 2012, 04:37
Hi there,
usually the internal field is a vector specified with the key word internal field
see therefore the user manual as reference.
as Simone I used the simpleFoam solver, but my knowledge concerning the
solvers is limited and I used the GAMG according to a recommendation.
My settings for U you can read from my previous posts
and the fvSchemes looks as follows:
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss linearUpwind Gauss linear;
    div(phi,nuTilda) Gauss linearUpwind Gauss linear;
    div((nuEff*dev(grad(U).T()))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
    laplacian(1,p)  Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
NOTE: this is what I used for OF 1.7.1 eventually notation and settings
have changed
MRFSimpleFoam wind turbine case continuity error ysh1227 OpenFOAM Running, Solving & CFD 1 August 16, 2016 10:25
MRFSimpleFoam wind turbine case diverges ysh1227 OpenFOAM Running, Solving & CFD 2 May 7, 2015 11:13
Inviscid 2D Airfoil Case doug OpenFOAM Running, Solving & CFD 8 October 13, 2010 08:06
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 19:36
oscillating airfoil test case Akbar Main CFD Forum 1 July 22, 2005 12:49
