coding problem in Openfoam
Old   September 19, 2012, 19:22
Default coding problem in Openfoam
conceptone is on a distinguished road
Hi everyone, right now I am reading the code in openfoam. I usually read this definition like this: const scalar time = this->owner().solution().trackTime();
so what does the owner mean? I mean is it a class or a file name? And I never found the definition for "TrackData". Any help? Thanks.
conceptone is offline   Reply With Quote
Old   September 20, 2012, 13:28
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
owner is a member function for the current dynamically allocated object. What class are you exploring? If you want better understanding of the inheritance that happens in OF, use the doxygen documentation:
http://www.openfoam.org/docs/cpp/
You can search for the member owner and see what the function is all about. Looks like the return type has a member named solution which has a member named trackTime.
Morpheus: This is your last chance. After this, there is no turning back. You take the blue pill - the story ends, you wake up in your bed and believe whatever you want to believe. You take the red pill - you stay in Wonderland and I show you how deep the rabbit-hole goes.
mturcios777 is offline   Reply With Quote
Old   September 21, 2012, 01:57
Thanks man!
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
problem with sampling Utility in openFOAM 1.6 carmir OpenFOAM Post-Processing 10 February 26, 2014 03:00
binutils-devel problem with Openfoam abminternet OpenFOAM 1 June 18, 2011 08:39
OpenFOAM 1.6 CreatePatch Problem TarifaPirata OpenFOAM Bugs 1 September 10, 2009 05:35
Adventure of fisrst openfoam installation on Ubuntu 710 jussi OpenFOAM Installation 0 April 24, 2008 15:25
