Import solution from a Fluent simulation
Old   September 17, 2012, 10:40
Default Import solution from a Fluent simulation
Samuele Z
samiam1000 is on a distinguished road
Dear Foamers,
I have a steady solution obtained with Fluent and I would like to know if it is impossible to import it, in order to use it as initial solution for an unsteady simulation with OF.
Of course, the mesh is the same.
Thanks a lot for help.
Samuele
samiam1000 is offline   Reply With Quote
Old   September 18, 2012, 05:01
Olivier
olivierG is on a distinguished road
hello,
There is a tool in the 1.6-ext called "fluentDataToFoam" which should do the job.
So you need to try the 1.6-ext version, or try to copy & compile in your 2.1 version.
regards,
olivier
olivierG is offline   Reply With Quote
Old   September 18, 2012, 05:44
Samuele Z
Thanks a lot.
I tryed to compile it, but it does not work.
I'll work on it.
Thanks a lot,
Samuele
Fluent exceeding Solution Limits on faces bawfuls FLUENT 3 July 10, 2012 17:34
I hope you can point out problems in my FLUENT solution tp9180188 FLUENT 2 March 15, 2012 12:40
Chemical Equilibrium Simulation using Fluent enigma ANSYS 2 October 27, 2011 09:02
FLUENT (2D simulation) virginia FLUENT 3 January 28, 2011 03:24
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
