which Solver for Hot Cold Water mix
Old   September 12, 2012, 13:55
Default which Solver for Hot Cold Water mix
Erkan
uwsa is on a distinguished road
Hi all Foam Users,
I would like to simulate a pipe flow with
two inflows ( first inflow cold 35 Celsius) (second inflow 100 Celsius)
and one outflow with the mixture of both.
The pressure is about 8 MPa.
I checked the tutorials but could not find a corresponding case.
Does anybody know which solver could be useful for my case?
Thanks a lot.
uwsa is offline   Reply With Quote
Old   September 18, 2012, 04:40
Sachin Kanetkar
sachin is on a distinguished road
Hi ...
you already have icoFoam case for flow mixing from two inlets ...
same as fluent tutorial case ...
you just need to add the temperature equation to icoFoam (wiki page already there explaining it) and run the case ...
sachin is offline   Reply With Quote
Old   July 30, 2013, 08:39
Vishal
inf.vish is on a distinguished road
Can you share your insights on the above problem?
I would like to solve a similar problem. T joint mixing of two streams of water at different temperatures.
inf.vish is offline   Reply With Quote
Old   July 30, 2013, 16:58
Nima Samkhaniani
nimasam is on a distinguished road
use bouyantBoussinqSimpleFoam
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   July 30, 2013, 23:36
Vishal
The problem with buoyantBoussinesqSimpleFoam is that i can set temperature boundary conditions at the two inlets but the fluid as such does not flow at the said temperature. The fluid simply carries the heat with it. I ran the case with buoyantBoussinesqSimpleFoam and looked at the temperature profiles at different times and i can see how to fluid carries the heat. That is not my aim.I want fluid at 600K to enter the inlet.
Kindly tell me the boundary conditions for having a fluid at 600K enter the inlet if you are using buoyantBoussinesqSimpleFoam.
I found a thesis paper which says about mixing of hot and cold water with turbulence and he has used dnsFoam to solve. Also, he hasn't mentioned the codes. Can you guide me further on this simple problem. I have been stuck on this problem for three days
Old   July 31, 2013, 04:19
Vishal
i have attached an image showing what exactly i want to do.
File Type: jpg Screenshot from 2013-07-31 12:46:26.jpg (23.8 KB, 127 views)
Old   July 31, 2013, 05:32
Nima Samkhaniani
what contour is it? is it temperature contour?
Old   July 31, 2013, 05:35
Vishal
Yes that is the temperature contour.
Old   July 31, 2013, 05:36
Vishal
This example is very simple to solve on fluent. Why the difficulty in solving in OpenFOAM?
I understand that buoyantBoussinesqSimpleFoam can be used. But how do i achieve the fluid entering at different temperatures.
Old   July 31, 2013, 05:43
Nima Samkhaniani
it's also easy in OpenFOAM, you need to define two inlets as you defines your geometry! give one inlet T1 and the other one T2
There is no hard task here
Old   July 31, 2013, 05:45
Vishal
I did that. But that boundary condition just implies that the two inlets are at T1 and T2. It does not imply that the fluid entering them is at T1 and T2.
Old   July 31, 2013, 05:55
Nima Samkhaniani
its an well-known elbow mixing problem, you can see at picture (temperature contour) that two hot and cold waters are mixing together here!
i used buoyantBoussinesqSimpleFoam! for this problem. so i did not get what the problem is. when you assign a fixed temperature at inlet you force the solver to consider the inlet fluid with that temperature , i dont understand why do u separate them
Old   July 31, 2013, 05:58
Vishal
Okay. Thanks. I didn't know how OpenFOAM was treating that particular temperature boundary condition. I was thinking it as a Heater kept at the inlet, sort of a film of heat.
Thanks once again
can you share your boundary conditions for p,U,p_rgh and T. I am a bit confused on p_rgh and p.
Old   July 31, 2013, 09:35
Nima Samkhaniani
i suggest you to read the first chapter of userguide and work with some tutorial cases you will find how to assign your BCs
and about
p_rgh and p
you need just assign BC for p_rgh which is pressure minus hydrostatic effect, p will be BC write then by solver, for p, BC can be consider as calculated
Old   May 28, 2017, 07:04
arianna sterpi
ari92 is on a distinguished road
How should be the velocity profile at the outlet section for this problem?
ari92 is offline   Reply With Quote
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Simulating Water Splash Using a Particle System Zi-Wei Chiou Main CFD Forum 0 March 4, 2002 07:33
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 17:25
Error during Solver cfd guy CFX 4 May 8, 2001 07:04
