AMI speed performance
Like Tree5Likes
Old   April 10, 2020, 06:51
le
fsifsi is on a distinguished road
Dear wyldckat
Really much appreciated your kind help !
I follow your guide and compile my own new lib mesh. it works well if i run single cpu. For running parallel, it gets error when i decomposePar as following:
Processor 0: field transfer
--> FOAM FATAL IO ERROR:
keyword solidBodyMotionFunction is undefined in dictionary "/scratch/leqt/VIV/NACA/one-naca/0/pointDisplacement.boundaryField.airfoil1.multiMoti onCoeffs"
file: /scratch/leqt/VIV/NACA/one-naca/0/pointDisplacement.boundaryField.airfoil1.multiMoti onCoeffs from line 55 to line 71.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 437.
FOAM exiting
I use OF2.3.0
Could you have some comments , please ?
fsifsi is offline   Reply With Quote
Old   October 24, 2020, 05:13
Ali
AliVali is on a distinguished road
Hi le,
I hope you have solved the problem. I am having the smae problem with of2006 and also openFOAM 7. The model runs with single cpu, but sends the same error message in parallel.
I will be so grateful if you could reply.
Many thanks in advance,
Ali
AliVali is offline   Reply With Quote
ami angular speed ramp
OpenFOAM on Amazon Elastic Compute Cloud (Amazon EC2) piina OpenFOAM Running, Solving & CFD 14 November 11, 2015 14:17
[Other] Problem when case with AMI A.A. OpenFOAM Meshing & Mesh Conversion 1 October 4, 2012 12:54
Train Speed yeo FLUENT 5 February 14, 2012 09:38
parallel performance on BX900 uzawa OpenFOAM Installation 3 September 5, 2011 16:52
Linux kernel performance enhancement ConnClark OpenFOAM 0 January 17, 2011 19:18
