irregular model simulation with chtMultiregionFoam
Old   December 28, 2013, 08:47
Kumudu
Kumudu is on a distinguished road
Originally Posted by wyldckat View Post
Hi Kumudu,
You're welcome!
Keep in mind that the "faceSet" is a selection of faces. So don't expect square-like faces to magically adjust to the shape of a cylinder face
In other words: the selection won't modify the mesh itself.
But you can do some mesh manipulation, once the correct selections are made and operated upon.
Not wanting to throw you off the right track, but this is just to give you an idea of what can be done with sets: http://openfoamwiki.net/index.php/SetSet#Usage_example - in that example, the idea is to select all cells and faces that are sort-of damaged and remove them completely by using subsetMesh to operate on the cell selection.
Best regards,
Bruno
Many thanks again. Do you mean that "createPatchDict" is better than "faceSet"?. So, what should I really have a look at between these two? Do you think "createPatchDict" will give better solutions without error?
I didn't really had time to go through the tutorial you sent me, because, I got some error in running the prepared case in the campus server. So, I am still figuring it out. Then, I have to look in to the tutorial you sent me.
Thanks again.
Best regards,
Kumudu
Kumudu is offline   Reply With Quote
Old   December 28, 2013, 09:40
Retired Super Moderator
Bruno Santos
No, no... sorry for the confusion. I should have let you first reach such a situation on your own. But I'm already planning ahead
The idea is that a "faceSet" allows you to select a specific group of faces in the mesh; this means that you could define the new "inlet" patch from, for example, a few faces from "maxY", instead of renaming the complete patch "maxY" in the respective region.
Attached is the image "example.png", that gives a better idea of what createPatch can do. In it you will see the possible scenarios:
  1. You can use createPatch to basically just rename a patch. This will work well if you only need to rename the whole patch, as exemplified, renaming "maxY" to "inlet".
  2. In case you want to create a new patch from a few faces in "maxY", you need to create a "faceSet" - named "f0" in this example - and then create the new patch "inlet" based on "f0". The remaining faces will still be part of "maxY".
The detail I was trying to indicate in the previous post, is that the faces selected with "f0", cannot be morphed directly into a circle. For that, you would need an additional application that would manipulate the mesh in a way that it would distort the mesh, by using the selection "f0" to know which faces needed to be manipulated.
The conclusion from all of this... is this: when you come to the point that you need the cylinder shape for the I-pipe, you need to design it directly in "blockMeshDict". Because topoSet and createPatch will only be able to do assign names to the existing mesh.
Old   December 28, 2013, 10:18
Kumudu
wow. You are a great teacher. Thanks alot. So, what if I create the cylindrical tube using topoSet, cylinderToCell. You mean I still cannot rename it using createPatch or faceSet. Only square shapes.
Thanks thanks.
Kumudu
Old   December 28, 2013, 13:18
Bruno Santos
Like I wrote/implied above, the sets (those created with topoSet or setSet) are only selections. You will be able to select cells whose centre is within the cylinder define with "cylinderToCell". But the cells will not change their shape! What you will get is very likely a cylinder made of cubes or bricks... unless you had already generated the mesh with a cylinder shape.
Give it a try and you will see for yourself what I mean
Old   December 28, 2013, 14:43
Kumudu
Thanks. I am trying to do that now.
Best regards,
Kumudu
Old   January 5, 2014, 05:57
Default Grading the mesh for chtMultiRegionFoam
  #26
Kumudu
Dear Bruno,
The instructions you gave worked perfectly. Now I have another problem, As I didn't give any cell expansion ratio, the number of cells are so high. Therefore, I cannot load the soil region to view in the paraview. So, I need to grade my blockMesh, as in the attached picture. Can you tell me how to do this?.
Thanks in advance.
Kumudu
Old   January 5, 2014, 10:09
Bruno Santos
Hi Kumudu,
I cannot open properly the DOCX file because I'm using LibreOffice. If you could attach in PDF format, it would be easier for me to properly see the content.
In general, there are at least 3 ways for creating a cell expansion:
  1. Do it directly in "blockMeshDict". Have a look into this file "incompressible/pimpleFoam/channel395/constant/polyMesh/blockMeshDict"
  2. Use a coarser mesh and then use refineWallLayer to add the layers.
  3. Use snappyHexMesh. You can turn off the first two stages of meshing and use only the add layers part.
I'm going to try and provide today a similar example here: http://www.cfd-online.com/Forums/ope...penfoam-2.html
Best regards,
Bruno
Old   January 5, 2014, 10:40
Kumudu
Hi Kumudu,
Best regards,
Bruno
Dear Bruno,
Thanks for replying me. Sorry. Here is the pdf version.
Best regards,
Kumudu
Last edited by wyldckat; January 5, 2014 at 11:53. Reason: merged the 2 posts, since they were 2 minutes apart...
Old   January 5, 2014, 11:58
Bruno Santos
Hi Kumudu,
Ah, much better! The PDF is a lot clearer!
I think you can easily use the current configuration you have for "blockMeshDict". You need to create a "cellSet" that selects all cells that are to be refined and then use refineHexMesh: http://openfoamwiki.net/index.php/RefineHexMesh
Example:
refineHexMesh c0
edit: Therefore, the order of execution should be:
  1. blockMesh
  2. topoSet
  3. refineHexMesh
Best regards,
Bruno
Old   January 5, 2014, 12:02
Kumudu
Hi Kumudu,
Example:
refineHexMesh c0
  1. blockMesh
  2. topoSet
  3. refineHexMesh
Best regards,
Bruno
Dear Bruno,
Many many thanks to you. I will do the way you said.
Best regards,
Kumudu
Old   January 5, 2014, 13:32
Kumudu
Dear Bruno,
Can you tell me, whether the following steps are correct ?
1.blockMesh
2.topoSet defining faceSet for inlet and outlet
3.createPatch -overwrite(rename the patches as inlet and outlet)
4. topoSet defining regions
5.topoSet to define cellSet that corresponding to fine mash
6.refineHexMesh
7.splitMeshRegions -cellZones -overwrite
Thanks ,
Best regards,
Kumudu
Old   January 5, 2014, 13:45
Bruno Santos
Hi Kumudu,
Good thing you listed the whole list. I forgot about splitMeshRegions. My advice is to do it in this order:
  1. blockMesh
  2. topoSet to define cellSet that corresponding to fine mesh (you can use the "-dict" option to define another dictionary; have a look into the tutorial script "combustion/fireFoam/les/oppositeBurningPanels/Allrun")
  3. refineHexMesh
  5. splitMeshRegions -cellZones -overwrite
  6. topoSet defining faceSet for inlet and outlet (don't forget the "-region" option)
  7. createPatch -overwrite (rename the patches as inlet and outlet) (don't forget the "-region" option)
I mention the "-region" option, because it makes more sense to me that you create the inlet and outlet patches only in the regions where you need them. Otherwise, you must do steps #6 and #7 before #5.
Best regards,
Bruno
Old   January 5, 2014, 13:52
Smile
  #33
Kumudu
Hi Kumudu,
  1. blockMesh
  3. refineHexMesh
Best regards,
Bruno
Thanks Bruno
Kumudu
Old   January 5, 2014, 14:58
Kumudu
Hi Kumudu
Best regards,
Bruno
Dear Bruno,
I am sorry for disturbing you. I actually did the other way around for the previous case, without go into refining the mesh
1.blockMesh
6.refineHexMesh
But, it gave me the solution. However, there was a problem in that.
It showed maxZ in the polyMesh/water, which shouldn't be there. But, Glyne showed that the direction of the velocity is correct. I just copied 0/water/T,
boundaryField
    maxZ -----------> this is the problem
        type            zeroGradient;
        value           uniform 274;
    inlet
        type            fixedValue;
        value           uniform 274;
    outlet
        type            zeroGradient;
        value           uniform 274;
    water_to_soil
        type            compressible::turbulentTemperatureCoupledBaffleMixed;
        value           uniform 274;
        neighbourFieldName T;
        K               basicThermo;
        KName           none;
I tried to do the way you told me before. That is running the topoSet for inlet and outlet case after the splitting the mesh. I included the topoSet for inlet and outlet in the system/water. Then, it gave me error. I don't know why is that.May be I didn't understood correctly,so
-------------> what do you mean by region option here, what is the comman line for that ,
I run the topoSet for inlet and outlet case as this :
runApplication topoSet -dict system/topoSetDict01
Didn't include the -region option
-------------> what is the command line for this?
Thanks Bruno,
Again sorry
Kumudu
Old   January 5, 2014, 16:04
Bruno Santos
Hi Kumudu,
The "-region" option, I referred to it here: http://www.cfd-online.com/Forums/ope...tml#post467877 post 18
Examples:
topoSet -region water
createPatch -region water
Have a look into the file "0/water/polyMesh/boundary". It should indicate all patch names and the number of faces associated to each one. The patch "maxZ" still has some faces associated to it.
Best regards,
Bruno
Old   January 5, 2014, 16:33
Kumudu
Hi Kumudu,
Examples:
Best regards,
Bruno
Dear Bruno,
Thanks. Yes, as you said, I looked in to the "0/water/polyMesh/boundary". There are faces associated to the maxZ. So, it means, if I included the topoSet for faceSet defining inlet and outlet in the system/water/topoSet01 and run (I don't understand the correct way to run)
topoSet -region water -dict system/water/topoSetDict1
and then,
include the createPatch in the system/water/createPatchDict and run as
createPatch -region water -dict system/water/createPatchDict
But, I got an error running the createPatch when I included the system/water/createPatch previously saying "cannot find the createPatch". At that time I didn't included the -region option.
I actually didn't previously understood the "-region option". Sorry. Could you please tell me the correct way to run it?. I think the command lines are wrong.
Best regards,
Kumudu
Old   January 5, 2014, 17:41
Bruno Santos
Hi Kumudu,
I need to see the full command you used and the full output message from that command. Otherwise, I can't deduce what went wrong.
The reason why there are still faces associated to "maxZ" is probably because the inlet and outlet do not fully replace all faces for it.
If you can share the case you have right now, it's easier to help you.
Best regards,
Bruno
Old   January 5, 2014, 18:05
Kumudu
Hi Kumudu,
Best regards,
Bruno
Dear Bruno,
I am attaching the file.
Thanks again,
Kumudu
Old   January 5, 2014, 19:05
Bruno Santos
Hi Kumudu,
First problem - this line:
topoSet -dict system/topoSetDict1
Should be:
Reason: topoSet was complaining that it could not open the file "system/topoSetDict1", because it didn't exist, since the correct name was "system/topoSetDict01" .
Same goes for "system/topoSetDict2" -> "system/topoSetDict02".
As to explain what I meant before - you currently have got this:
runApplication blockMesh
runApplication createPatch -overwrite
runApplication topoSet -dict system/topoSetDict02
runApplication splitMeshRegions -cellZones -overwrite
According to my step list from post #32, it should look something like this (lines that start with # are comments):
#define the cell set "cellSetForRefinement" for the refinement and then refine
runApplication topoSet -dict system/topoSetDict00
runApplication refineHexMesh -overwrite cellSetForRefinement
#define the zones for the regions and split the mesh into regions
#define the faceSets for the inlet and outlet patches and create the patches
runApplication topoSet -dict system/topoSetDict01 -region water
runApplication createPatch -overwrite  -region water
Best regards,
Bruno
PS: I will probably only be able to answer to questions in 6-7 days from now. Good luck!
Old   January 6, 2014, 16:15
Kumudu
Dear Bruno,
Thank you very much. I actually run,
I didn't use the Allrun command. That is why I forgot to put the correct name for the topoSet in the Allrun file. Sorry for that. Now I understand correctly. Thank you very much. Without your help , I will be stuck in my thesis.Now I am really happy.
Thanks,
Kumudu
Hi Kumudu,
Dear Bruno,
I will need to run the refineMeshDict for more than once. I saw that refineMesh has been used in the multiphase/cavitatingFoam/les/throttle/Allrun as follows,
refineMeshByCellSet()
   while [ $# -ge 1 ]
   do
      if [ ! -e log.refineMesh.$1 ]
      then
          echo "creating cell set for primary zone - $1"
          cp system/topoSetDict.$1 system/topoSetDict
          topoSet > log.topoSet.$1 2>&1
          echo "refining primary zone - $1"
          refineMesh -dict -overwrite > log.refineMesh.$1 2>&1
      fi
      shift
   done
refineMeshByCellSet 1 2 3
runApplication $application
# ----------------------------------------------------------------- end-of-file
Can you explain the above lines a little bit. I think this explains how to run the same cellSet again and again.
Thanks in advance,
Kumudu
Last edited by wyldckat; January 10, 2014 at 15:19. Reason: merged 2 posts - fixed broken quotes and code markers
fields chtmultiregionfoam
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
LES simulation with Smagorinsky2 model Zuixy OpenFOAM Running, Solving & CFD 3 October 20, 2011 07:17
Turbulence model in a simulation with wide spatial range of Reynolds numbers Chander CFX 33 September 28, 2011 09:48
Experimental And Simulation Data for my model Timothy Song Siemens 0 January 12, 2009 06:23
