What model of turbulence choose to study an external aerodynamics case
Old   August 23, 2012, 06:45
Default What model of turbulence choose to study an external aerodynamics case
raffale is on a distinguished road
Hello everyone,
I'm pretty new in cfd so maybe you'll find my questions basics. What model of turbulence choose to study an external aerodynamic case?
Here is my situation:
I want to model the aerodynamic track of a ship to investigate its effect on a helicopter during landing at the back of the ship. The wind upstream is equal to 12.85 m/s. And my Reynolds number is 10^6-10^7.
My Mesh refinement is not really good but I can't make better because of my computer. I use boundary condition type fan to model the helicopter's rotor.
Until Today I use standard K-Epsilon (High Re) model to perform my calcul but now I'm more experienced and I believe I should use K-Omega SST model. I try to use K-Omega SST model but my results are completely different and it seems that the results are less consistent than for the standard K-Epsilon model. Is it normal?
EDIT: I used simpleFoam to compare the 2 models of turbulence.
Please can you give me your opinion? Maybe I should try an another model of turbulence like K-epsilon (Low Re)
It's been 2 months since I have worked on the standard k-Epsilon model and and I do not need to have a good accuracy for my results. I just want the good behavior of the air. The standard K-Epsilon I used is it enough?
Regards,
raffale
raffale is offline   Reply With Quote
Fluent :- turbulence Model prince_pahariaa FLUENT 9 May 20, 2016 04:41
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
SimpleFoam case with SpalartAllmaras turbulence model implemented nedved OpenFOAM Running, Solving & CFD 2 November 30, 2014 23:43
Wrong calculation of nut in the kOmegaSST turbulence model FelixL OpenFOAM Bugs 27 March 27, 2012 10:02
Why Turbulence models are not universal. Senthil Main CFD Forum 4 July 5, 2000 05:34
