Defining convergent gravity field! please Help me
Old   July 30, 2012, 08:15
adambarfi's Avatar
Mostafa Mahmoudi
adambarfi is on a distinguished road
Send a message via Yahoo to adambarfi Send a message via Skype™ to adambarfi
hi Nima,
I'm pretty a new user of OF in compare with you,
can you explain me how can I define the position vector?
where should I define it? I'm using the buoyantBoussinesqSimpleFoam. should I remove the g file in constant directory?
can you attach me an example?
actually I know what to do but I cannot Implement it in OpenFOAM!!!!!!!
please help me, I'm so confused.
thank you
adambarfi is offline   Reply With Quote
Old   July 30, 2012, 16:04
Nima Samkhaniani
nimasam is on a distinguished road
hi newbie
do you know how to implement a code at OpenFOAM at all?
1) first read user guide chapter 3 if i was true , it tells you how to compile a code
2) read programmer guide, it has 2,3 example how to implement a code
3) you can find some tutorials about how to add a source term to a solver or how to add energy equation into a solver in Internet. it gives you enough information how to start
4)the last but not the least , if you live in Iran/Tehran you can attend at ISME OpenFOAM workshop, hold by myself, i teach these things there
nimasam is offline   Reply With Quote
Old   July 31, 2012, 16:18
adambarfi's Avatar
Mostafa Mahmoudi
Originally Posted by nimasam View Post
hi newbie
Dear Nima,
Thank you for your reply. again I rummage the user guide and programmer's guide, but I catch anything. there wasn't any example or hint for defining a position vector.
till now I just change the geometry of OF examples and I've applied only small change in codes. I didn't implement a code myself, I just changed them.
unfortunately, I don't live in Tehran, I'm a bachelor student of Shahrood university of technology and now I'm at Torbat-e Heydariyeh.
can you help me that how and where can I define a position vector? if I define it, it is possible to change the g.
of course, I'm trying to define this vector by chance!!!! I hope I can do it
Thank you
Old   July 31, 2012, 19:55
Nima Samkhaniani
i suppose you know how to change a code
you need define a volVectorField g (do you know, how?, look at code and see how velocity is implemented)
then you need to access position vector:
poistion vector can be accessed by: U.mesh.C()
and you need to read the center position vector from dictionary (see how gravity vector is implemented)
i know, you know the rest, you should implement the function i mentioned in previous post.
Thats it!
Old   August 1, 2012, 13:34
adambarfi's Avatar
Mostafa Mahmoudi
Thats it!
thank you dear Nima,
I'm trying and some advances were made!!!!
I promise if I couldn't solve this problem, again I will be back
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
Zero size field taranov OpenFOAM Bugs 2 April 20, 2010 05:51
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
