July 24, 2012, 06:53 |
continuity Error when using mapFields
Samuele Z
Rep Power: 19 |
Dear all,
I am trying to use the mapField command. Indeed, it works pretty well. The point is that I get an error when I try to launch the buoyantSimpleFoam command. The error is the following: Code:
rduser@slnxepmi05:/OPENFOAM/cases/moving_door_def_flow/0DegStartSimple$ buoyantSimpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : buoyantSimpleFoam Date : Jul 24 2012 Time : 11:40:20 Host : "slnxepmi05" PID : 24038 Case : /OPENFOAM/cases/moving_door_def_flow/0DegStartSimple nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Reading thermophysical properties Selecting thermodynamics package hPsiThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>> Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kEpsilon kEpsilonCoeffs { Cmu 0.09; C1 1.44; C2 1.92; C3 -0.33; sigmak 1; sigmaEps 1.3; Prt 1; } Calculating field g.h Reading field p_rgh SIMPLE: convergence criteria field p_rgh tolerance 0.01 field U tolerance 0.001 field h tolerance 0.001 field "(k|epsilon|omega)" tolerance 0.001 Starting time loop Time = 1 DILUPBiCG: Solving for Ux, Initial residual = 0.75027308, Final residual = 0.0059180187, No Iterations 1 DILUPBiCG: Solving for Uy, Initial residual = 0.97031907, Final residual = 0.0078913271, No Iterations 1 DILUPBiCG: Solving for Uz, Initial residual = 0.82258021, Final residual = 0.0061307245, No Iterations 1 DILUPBiCG: Solving for h, Initial residual = 0.00024857446, Final residual = 2.2807101e-06, No Iterations 1 --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 1226.2338 Specified mass inflow : 1.074375 Specified mass outflow : 1.0743555 Adjustable mass outflow : 0 From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file cfdTools/general/adjustPhi/adjustPhi.C at line 118. FOAM exiting rduser@slnxepmi05:/OPENFOAM/cases/moving_door_def_flow/0DegStartSimple$ Thanks a lot, Samuele |
November 20, 2017, 15:40 |
Bhanu
Rep Power: 12 |
Hi Samuele,
Were you able to resolve this ? I have the same issue. Especially I want to convert the fixed Value ( zero) pressure outlet to fixed flux pressure or zerogradient and I have the simulation being run. When I tried to map to the test cases with new boundary conditions, it gives the same error. Thanks in advance. Cheers |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
