coupling of two mesh OpenFOAM
Old   July 14, 2012, 07:43
Exclamation coupling of two mesh OpenFOAM
omar_beg
dima13 is on a distinguished road
how to glue two geometry
I have two blockmeshdict, with the same number of block and even Neaud
and I want to make a coupling between the two forms
soon as possible
thank you
dima13 is offline   Reply With Quote
Old   July 14, 2012, 13:10
Retired Super Moderator
Bruno Santos
Greetings dima13,
It really depends on what you want to do.
If you want to merge the meshes, look for "mergeMesh" or "stitchMesh" here in the forum.
If you want to have different fluids or bodies interacting between the two meshes, you have chtMultiRegionFoam on most OpenFOAM versions, and conjugateHeatFoam on the variant OpenFOAM 1.6-ext.
Best regards,
Bruno
[Other] OpenFoam Mesh to Fluent Mesh, 2D lordvon ANSYS Meshing & Geometry 1 January 14, 2022 13:20
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 03:54
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
Mesh Check fails in OpenFoam ???? Gitesh P OpenFOAM 3 June 30, 2011 06:48
