July 4, 2012, 11:18 |
InterFoam - Dambreak - alpha
ernest
Rep Power: 15 |
Hello OpenFOAMERS, I am a beginner with regards to OpenFOAM. Currently I am stuck on the Dam break problem in OpenFOAM. My case is different because the obstacle is a cylinder which has a virtual boundary (through an immersed boundary method -IB). The immersed boundary method uses a simple non-conforming Cartesian grid. Consequently, the boundary of the cylinder is not explicitly defined, but it is implied through a virtual force. Because of this virtual boundary, I am having difficulties resolving the interface around the cylinder. In order to force the liquid phase to stay outside the cylinder, I have (and I am not sure if I am right here) modified alpha1 (in alphaEqn.H) to alpha1 = alpha1(1 - A123), where A123 = 1 within the cylinder and zero outside the cylinder. My main problem is that when I explicitly solve for alpha (in the alphaEqn.H), the value of alpha is not conserved and becomes unbounded to values much higher than one. Please, I request your help in trying to resolve this problem.
Ernest |
alpha becomes bigger than 1 in interFoam | ata | OpenFOAM | 1 | March 21, 2020 14:49 |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 16:12 |
InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 03:41 |
Moving from simpleFoam to interFoam with alpha = 0 | kjetil | OpenFOAM Running, Solving & CFD | 1 | November 8, 2009 20:04 |
alpha or alpha1 in interFoam & interDyMFoam | wavytracy | OpenFOAM Bugs | 3 | September 10, 2009 02:51 |
