Melika
Rep Power: 14 ![]() |
Hi everyone
I am doing simulations for a pipe with an obstacle inside using LES in openFOAM. I have recently got some results for pressure and velocity. Velocity data looks fine but pressure changes linearly from inlet to the outlet which for sure is not correct. ![]() I am wondering if channelFoam assumes a constant pressure gradient. I would appreciate any comment about this problem. Thanks. |
Franco Marra
Rep Power: 17 ![]() |
Dear Libra,
channelFoam adds a constant (in space) pressure gradient to the momentum equation and corrects it every time step to ensure the flow rate desired. For a periodic channel without obstacles the pressure have to vary linearly from inlet to outlet. Therefore this pressure contribute tends to be the only one in the average. Of course, when turbulence develops, the computed pressure (from the elliptic equation) have to equilibrate the flow, so that proper fluctuations have to appear in the computed pressure field. However I can expect that the intensities of these fluctuations are much smaller than the average pressure variation. Are you sure you are not missing your pressure variations just because of the way you observe them ? Best regards, Franco |
Melika
Hey Franco
Thanks for your reply. As you said pressure gradient should be corrected for every time step. But it seems that it has not happened in my case. ![]() I checked pressure data for some time steps in paraFoam and for all of them pressure gradient has a constant value. ![]() I have started running my case with paraFoam and I do not have such a problem when using this solver. I'm still wondering why my pressure data is like this. ![]() Thank you again. Melika |
Franco Marra
Dear Melika,
it is not easy to help with so few info. I will try. paraFoam is just a postprocessing utility, so I do not understand what exactly you mean when you say that you had no problems computing the pressure with this application. In the first message you noticed that velocity data looks fine. Now velocity cannot be good if pressure is not correctly solved. Maybe your problem is just to correctly visualize your results. I would try to use foamToVTK to transform all your time data in the native format of Paraview and then use paraview directly to load and animate all time steps you saved of your computation. For more help, more details about your case and setup and some images of results are needed. Best regards, Franco |
Melika
Hey Franco
Thanks again for your reply. ![]() ![]() I have attached a view of my case. I have got a long pipe with a half-disk obstacle inside. I also attached this file "line_p_k.xy" for one time step. In this file the first column is the coordinate on the center line from the inlet to the outlet. As you see if you plot the second column (P) vs. the first column you will get a line. ![]() ![]() I will appreciate any comment. Thanks a lot. Melika Mesh.jpg line_p_k.txt |
Pressure Outlet Guage pressure | Mohsin | FLUENT | 36 | April 29, 2016 17:16 |
how to get pressure and pressure gradient using UDF | Honglin | Fluent UDF and Scheme Programming | 0 | May 24, 2012 06:47 |
lid-driven cavity in matlab using BiCGStab | Don456 | Main CFD Forum | 1 | January 19, 2012 15:00 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 06:52 |
Inputting pressure gradient in Fluent | Josyula | FLUENT | 2 | December 23, 2009 07:26 |
