k-epsilon model
Old   June 28, 2012, 20:48
Default k-epsilon model
yu
xiyuqiu is on a distinguished road
Hello all,
Does anyone know what are (or where to find) the default value that OpenFoam uses in its standard k-epsilon model? Many thanks.
best
xiyuqiu is offline   Reply With Quote
Old   June 29, 2012, 02:40
Eysteinn Helgason
eysteinn is on a distinguished road
At least in openfoam 2.0.1 it can be found is in:
/src/turbulenceModels/incompressible/RAS/kEpsilon
Just take a look at the .H or .C file.
/Eysteinn
eysteinn is offline   Reply With Quote
Old   June 29, 2012, 05:32
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
This is the content of the file RASProperties:
RASModel        kEpsilon;
turbulence      on;
printCoeffs     on;
if you set printCoeffs to on, then OF will print the coefficients of the turbulence model at the beginning of the simulation.
If you want to change some values add this to RASProperties
kEpsilonCoeffs
    Cmu         0.09;
    C1          1.44;
    C2          1.92;
    C3          -0.33;
    sigmak      1.0;
    sigmaEps    1.11; //Original value:1.44
    Prt         1.0;
GerhardHolzinger is offline   Reply With Quote
Old   June 29, 2012, 14:35
yu
Thank you so much. This is very helpful!! Do you also happen to know that if I would like to change those constants, where do I need to go? Are they defined in the source code? if so, if I change the values, I would need to recompiled the code, right? Or, there is a easier way to change the turbulent modeling constants. Thanks again.
best,
yu
RASModel        kEpsilon;
turbulence      on;
printCoeffs     on;
kEpsilonCoeffs
    Cmu         0.09;
    C1          1.44;
    C2          1.92;
    C3          -0.33;
    sigmak      1.0;
    Prt         1.0;
Old   July 2, 2012, 04:29
Gerhard Holzinger
my second code example shows you how to manually override the default values. There is no need to change the default values in the code, if you can override them.
If you wanted to change the values right inside the code, you should look at e.g. src/turbulenceModels/incompressible/RAS/kEpsilon/kEpsilon.C
I assume the recommended way to do a calculation with non-default model constants is to define them in RASProperties. Also, if you do a calculation with non-default model constants you should make sure the coefficients are printed at the beginning of the calculation (printCoeffs on). So you can check afterwards which values were used.
The easiest way to change the turbulent model constants is to define them in RASProperties
Old   July 2, 2012, 12:57
yu
Got it. Thanks!!!
Old   July 29, 2012, 03:12
Default help please
vahid
vahid.najafi is an unknown quantity at this point
Hello dear foamers.
I have a question, please answer this.
I want to add k(kinetic turbulence energy) in solver interPhaseChangeFoam.
for this reason, added next line in this:
const volScalarField &k=U_.db().lookupObject<volScalarField>("k")
and wmake was Successfully .
but How can I Understand that this k is the same with k(kinetic turbulence energy)???Is it true?????or not????
Because I replased M Instead k in Top Line :
const volScalarField &M=U_.db().lookupObject<volScalarField>("M")
but nothing error was not occured!!!!!!??????
vahid.najafi is offline   Reply With Quote
Old   July 29, 2012, 09:44
Nima Samkhaniani
nimasam is on a distinguished road
this program will be compiled with no error! but do you run your case with it?
this line will be looking for volScalarField M, and if it can not find, it will give you fatal error
nimasam is offline   Reply With Quote
Turbulence Model and limitation to Reynolds number qascapri FLUENT 0 January 24, 2011 11:48
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
k and epsilon discretization of RNG model mehran Fidelity CFD 0 January 24, 2009 01:01
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
K-Epsilon Model sangit Main CFD Forum 2 September 9, 2004 14:19
