Algebraic Model for Variance - grid size surface field
Old   June 28, 2012, 06:03
Default Algebraic Model for Variance - grid size surface field
alessio.nz's Avatar
Alex
alessio.nz is on a distinguished road
I have a rhoPimpleFoam solver which solve the equation for an extra scalar equation c (progress variable) and an algebraic equation for its variance.
The model for the variance is var (c) = a * (Delta X)^2 * (grad (c))^2
where the Delta X is the grid size, a is a constant (0.08333) and grad (c) is the gradient of C field.
The solver upload the data for progress variable (which goes from 0 to 1) and variance (which goes from 0 to 0.25) from a two dimensional table .
Table looks like:
Variance PV other variables
0 0
: 1
0.1 0
: 1
0.5 0
: 1
My questions are the following:
1) I defined the grid size field in the following way and I would like to know if it's correct
surfaceScalarField GridSize
IOobject
"GridSize",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
mesh,
dimensionSet(0,-1,0,0,0,0,0)
GridSize = mesh.surfaceInterpolation::deltaCoeffs();
2) My secondo question is:
considering the equation for the variance:
VarC.internalField() = pow((GridSize.internalField(),2)*0.08333*magSqr(fv c::grad(C));
when I run the simulation, after a few iterations, the variance goes out of bound (despite I impose to stay inside the limit of 0-0.25) and the simulation crashes soon.
Is that have something to do with the gridsize definition?
thanks for the help
alessio.nz is offline   Reply With Quote
Weld surface deformation by VOF model minhaj_iut FLUENT 5 February 27, 2017 00:51
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Grid resolution in porous medium model for heat sink Chander CFX 4 April 2, 2012 08:10
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 12:22
Reynolds transport, turbulence model, etc Beginner Main CFD Forum 1 January 7, 2009 06:36
