Dynamic Mesh for a Gear Pump
Like Tree56Likes
Old   June 27, 2012, 08:45
Post Dynamic Mesh for a Gear Pump
TRT
TRT is on a distinguished road
Hi all. My name is Alejandro Roger Ull. This spring I've been working on my final project for my aerospace engineering degree. I did a study on how to work with dynamic meshes in OpenFOAM, in particular for its application to a gear pump simulation. I want to share my work with you, so that anyone that may find it helpful can access to it.
Gear Pump Animation
The work consists on meshing the geometry with snappyHexMesh in parallel and extruding it with extrudeMesh to make it two-dimensional. Then a custom boundary condition for the movement of the mesh is created. Finally the simulation is run in parallel, by generating an initial mesh, moving it as much as possible, up to acceptable limits of deformation, and finally replacing it with a new mesh. Everything is completely automated.
You can download the document here. (2.63 MB) (CC BY-NC-SA 3.0)
Also, all the files I used can be downloaded here. (9.12 MB) (CC BY-NC-SA 3.0)
If you have any comments feel free to post them here.
Terrassa Rocket Team Blog: http://terrassarocketteam.blogspot.com/
Last edited by wyldckat; May 12, 2014 at 16:41. Reason: fixed link to PDF on request from post #21
TRT is offline   Reply With Quote
Old   July 3, 2012, 06:26
James Willie
jwillie2000 is on a distinguished road
Hi TRT,
You did a good job and thanks for sharing. I am about to do a moving mesh simulation in ANSYS Workbench and I am new to it. So i am trying to gather some info. The gear pump u described is similar to what i am looking at, even though the principles are a bit different. I wanted to know whether you did a similar mesh in ANSYS Meshing?
Thanks!
Jimmy
jwillie2000 is offline   Reply With Quote
Old   July 3, 2012, 06:44
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Nice job, thank you for sharing!
lovecraft22 is offline   Reply With Quote
Old   July 6, 2012, 15:27
TRT
Hey Jimmy, unfortunately I do not have a clue about how to do this with ANSYS Workbench, so I can't help you. Thanks for your interest anyways.
Old   July 30, 2012, 09:58
jwa
jwa is on a distinguished road
Hi Jimmy, you may want to look at http://www.adina.com/newsgH107.shtml for a FSI gear pump analysis
jwa is offline   Reply With Quote
Old   August 1, 2012, 11:25
Stefan
shanxuewenjdx is on a distinguished road
So can ADINA simulate the inner flow of gear pump in 3D?
shanxuewenjdx is offline   Reply With Quote
Old   August 1, 2012, 11:43
Default Gear Pump analysis
jwa
Hi shanxuewenjdx, Yes it can. The other examples on the webpage are 3D eg the flow meter. Exactly the same capabilities are used.
Old   December 27, 2012, 13:38
immortality's Avatar
Ehsan
immortality is on a distinguished road
hello Alejandro
could yu please send me the complete pdf?
thanks.
force.of.love@gmail.com
immortality is offline   Reply With Quote
Old   December 27, 2012, 13:44
TRT
There is a download button on my first post, and then another one on the dropbox webpage (top right).
Old   January 24, 2013, 22:45
Wang Jianli
sparkbjfu is on a distinguished road
I am very happy to see your share, cause I'm going to do an analysis just like that, but I'm in China, there are some reasons to block me from downloading those files by clicking the URL you give, would you please send me the PDF and case files in a zip?
My email: jianli.bjfu@163.com
Thank you!
sparkbjfu is offline   Reply With Quote
Old   July 13, 2013, 15:29
erfan-BA
88481101 is on a distinguished road
hi,
can you send your results to me?
I need it immediately for my final project.
kind regards,
behnam Akhoondian
b.akhoondian@gmail.com
88481101 is offline   Reply With Quote
Old   July 27, 2013, 15:51
erfan-BA
hi sparkbjfu,
did U finished your project? if U completed it,can you tell me how you changed the trt's geometry to your own geometry?
best regards,
Old   August 16, 2013, 13:36
YaoHD
happydogy is on a distinguished road
Nice work!
happydogy is offline   Reply With Quote
Old   September 5, 2013, 19:21
Tom Li
beancurd70 is on a distinguished road
Thank you for sharing!
beancurd70 is offline   Reply With Quote
Old   September 5, 2013, 21:28
Default Gear pump and moving mesh tutorial with custom BC
  #15
JR22's Avatar
Jose Rey
JR22 will become famous soon enough
Excellent tutorial, you even go through the stumbling blocks in the process. Thank you very much for sharing
JR22 is offline   Reply With Quote
Old   September 18, 2013, 06:49
Vishal
inf.vish is on a distinguished road
Gear Pump Animation
Hi Alejandro Roger Ull,
I was curious if the same problem can be solved using immersed boundary method in openFoam?
inf.vish is offline   Reply With Quote
Old   September 19, 2013, 13:53
CThib is on a distinguished road
Thank you for sharing.
CThib is offline   Reply With Quote
Old   September 22, 2013, 11:36
TRT
I know little about the immersed boundary method (I've only read about it because of your post), but, as far as I know, I don't think it will work. It seems to me that the immersed boundary method is useful when your boundary moves because of the flow, in response to fluid forces (correct me if I'm wrong). But in this case the movement of the gears is known.
Also, take into account that the movement involved in the gear pump is so extreme that probably re-meshing is always needed at some point. You can try to separate the zone with large movements from other steady zones and then stick them together, so that you only have to re-mesh a smaller volume, in order to use less computational power.
Thank you all for your interest in my work.
Alejandro
Old   September 23, 2013, 07:45
Vishal
Alejandro
I was curious because Ansys CFX uses the immersed boundary method to solve for flows around a lobe compressor which is basically same as a gear pump.
Anyway, that project is scrapped now since OpenFOAM doesn't support immersed boundary methods.
Old   October 4, 2013, 09:25
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi TRT,
do you think that this will work for complex 3D simulations too? Its kind a hard work for such a job. I am interested in simulation of screw blower...
http://www.industriezeitschrift.de/g...er_element.jpg
Tobi is offline   Reply With Quote
boundary condition, extrudemesh, movemesh, parallel, snappyhexmesh
Gambit problems Althea FLUENT 22 January 4, 2017 04:19
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
Extended version: Dynamic mesh fusij OpenFOAM 2 February 18, 2011 03:12
Some questions about mesh updating in dynamic mesh technique lzgwhy Main CFD Forum 0 June 14, 2009 09:01
Dynamic mesh - structured mesh mrestrepo30 FLUENT 0 June 3, 2009 16:40
