Parallel Computing
Old   June 25, 2012, 19:55
Question Parallel Computing
Argen is on a distinguished road
I am using parallel computing for OpenFOAM and some FORTRAN subroutines are called by OF during computation. But, it's found that the errors occur when any Fortran subroutine (say my_test(a)) is called where a is defined as "double a[nCells]". The interesting is that it's no problem for calling it if a single processor is used. Any idea for this problem?
Argen is offline   Reply With Quote
Old   June 28, 2012, 13:44
any suggestion to sort it out?
Old   June 28, 2012, 18:07
Retired Super Moderator
Bruno Santos
Greetings Argen,
OK, the reason why it works in serial mode, but not in parallel, is very likely because "nCells" refers to the whole mesh and not the local processor's mesh only.
Uhm... I know there are applications in OpenFOAM that have similar needs, for both serial and parallel execution...
Sorry, I can't find any in a short period of time. You'll have to check the existing "applications" folder and see directly what code already exists that can do this.
The "applications/test" folder has many times true pearls of wisdom!
Here's an example that might be a good hint for what you're looking for - "applications/test/router/Test-processorRouter.C":
// Collect centres of individual meshes (for visualization only)
Gather<point> meshCentres(meshCentre(mesh));
The "Gather" template provides a way for gathering information from all processors. Nonetheless, this would imply that whenever you need to use the FORTRAN code, only the master processor could do the calculation...
Best regards and good luck!
Bruno
unchangeable continuity residuals in parallel computing wlt_1985 FLUENT 0 August 1, 2011 13:15
Diffusion equation solved using Parallel Computing Sachin Paramane Main CFD Forum 0 June 12, 2007 00:48
Parallel Computing on Multi-Core Processors Upgrading Hardware CFX 6 June 7, 2007 16:54
Parallel Computing peter Main CFD Forum 7 May 15, 2006 10:53
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
