June 18, 2012, 06:17 |
add concentration
anonymous
Rep Power: 14 |
Hello, I am using the case buoyantboussinesqpimplefoam and I would like to add concentration, as I can do it?
I have seen I have to follow the steps as in the tutorial to add temperature, but the equations are not the same, which ones I have to wear? I am new to OpenFOAM and I would like someone to help me. thanks! |
May 24, 2016, 22:25 |
#2 | |
Ping Chang
Rep Power: 10 |
Have you found the solution? |
May 24, 2018, 10:51 |
PATRICIA NAKANWAGI
Rep Power: 9 |
How were you able to add concentration in buoyantBoussinesqPimpleFOAM
May 24, 2018, 13:12 |
Uwe Pilz
Rep Power: 15 |
The differential equations for heat transfer and mass transfer are the same. You may set concentration as temperature. The thermal diffusity is equvalent to the diffusion coefficient. You may model the changes in fluid weight by concentration loss (at boundaries) too.
The problem I has is that temperature driven density changes and the thermal diffusity are much higher in comparision to mass transfer. It is numerical more demanding to calculate mass transfer. I got giant problems combinating free convection (fluid motion driven by density changes) with external flow, if I used coefficients typical for mass transfer.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
May 25, 2018, 08:15 |
PATRICIA NAKANWAGI
Rep Power: 9 |
Thank you Piu58,
My challenge is with trying to add concentration in buoyantBoussinesqPimpleFOAM. I am working on a case in which I am using the boussinesq approximation with density a function of both temperature and salinlity. The temperature scalar is already in the solver, need to add salinity too. kindly seeking some guidance on how I can be able to do this. Thank you |
May 25, 2018, 13:12 |
#6 | |
Uwe Pilz
Rep Power: 15 |
Mostly, it is not a good idea to put all the physics in one simulation. If there ist a way to split it, do.
dpm concentration | HK | FLUENT | 0 | March 6, 2008 06:44 |
Concentration Scale Data Interpretation | usker | Siemens | 4 | October 23, 2007 21:30 |
buoyancy force due to concentration difference | arsei0707 | Phoenics | 1 | December 14, 2005 06:11 |
negative species concentration again | Andrew Garrard | FLUENT | 0 | March 22, 2005 12:36 |
initial concentration in multicomponent mixtures | isidro | Siemens | 0 | April 26, 2004 08:40 |
