Eysteinn Helgason
Rep Power: 16 ![]() |
Hi all,
Is it possible to somehow run checkMesh on a decomposed case? Also yPlus and vorticity would be nice. I haven't found out how but maybe I'm missing something. . . . . /Eysteinn |
Olivier
Rep Power: 18 ![]() |
hello,
Yes, look at "checkMesh -help", you 'll find a -parallel option for this. Same for other tools i think. regards, olivier |
#3 | |
Eysteinn Helgason
Ok, I see. . . . . That means that I have to run my case on the same number of cpu-s as before? and then submit my job to the cluster once for each postprocessing step I guess? /Eysteinn |
Olivier
yes, or recompose your case (but i think this is really simpler to keep the decomposed case all the time).
regards, olivier |
#5 | |
Eysteinn Helgason
( I was hoping to be able to do this just locally still without recomposing my case. ) Edit: So Yes, It can be done locally by overloading the processors . . . . but it is slow. /Eysteinn Last edited by eysteinn; June 11, 2012 at 06:36. |
Is Playstation 3 cluster suitable for CFD work | hsieh | OpenFOAM | 9 | August 16, 2015 14:53 |
Error reading new case | montag dp | FLUENT | 5 | September 15, 2011 06:00 |
checkMesh and decomposePar crashes with salome IDEAS mesh | pajofego | OpenFOAM | 0 | June 23, 2011 08:43 |
[OpenFOAM] decomposed case reader in Paraview | cnsidero | ParaView | 2 | June 23, 2011 07:47 |
decomposed case to 2-cores (Not working) | pkr | OpenFOAM Running, Solving & CFD | 32 | February 27, 2011 18:04 |
