May 30, 2012, 04:33 |
Dependency of diffusivity from temperature
I try to modify laplacianFoam solver and make depency of DT from temperature. Something like this: if T>0 then DT=0.56 else DT=2.21. Taking a temperature from previous time layer is ok. But i don't understand how to make OpenFoam fill each value of dimensionedScalar from respective value of calculated T. |
May 30, 2012, 04:53 |
Nima Samkhaniani
Rep Power: 25 |
some thing like this:
forAll (T, celli) { if (T[celli] > 0) { DT[celli] =0.56; } else { DT[celli] =2.21; } } you should change diffusivity definition from dimensionedScalar into VolScalarField |
[swak4Foam] swak4foam building problem | GGerber | OpenFOAM Community Contributions | 54 | April 24, 2015 17:02 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
