Exchanging the geomtry in the LES motorBike tutorial
Old   May 26, 2012, 09:21
Default Exchanging the geomtry in the LES motorBike tutorial
Simon Arne
simpomann is on a distinguished road
Hey,
I guess this problem is fairly easy, but after 3 days of trying i decided that it is time to ask for help.
I want to exchange the geometry in the incompressible/pisofoam/les/motorbike - Tutorial. Sounds fairly easy right?
Without changes, the tutorial is working, except that i can only view the uncomposed results in the end or experience a paraView crash.
So i decided to delete the line from Allrun-script that copies the geometry from the tutorial. I put my own geometry that is called "motorBike.stl" in the triSurface folder and exchange the geometry name in the snappyHexMesh.dict (that before was motorBike.obj).
I also changed the vertices of the blockMesh and the searchable box of snappy hex mesh.
The settings for vertices,searchable box and the geometry are from a steady state case i set up on the usual motorBike tutorial and are working perfectly fine there.
Although i think there is a minor error in the geometry, as paraView crashes trying to open it. I tried to convert my stl to obj using meshlab, but can't figure out how it is done.
Thanks in advance and best regards,
Simon
openFoam 2.1.0 on Ubuntu 12.04, ptscotch in latest version
simpomann is offline   Reply With Quote
Old   May 26, 2012, 09:26
Default snappyHexMesh.log
Simon Arne
and the log of snappyHexMesh, the blockMesh log looks okay.
Incompressible LES tutorial (oodles) - time averaged statistics bernarde OpenFOAM 13 August 29, 2016 08:26
[snappyHexMesh] Trying to understand the motorBike tutorial Andyjoe OpenFOAM Meshing & Mesh Conversion 10 August 10, 2014 17:57
Wrong file in motorBike tutorial? lovecraft22 OpenFOAM 3 August 4, 2011 14:03
Basic question on motorBike tutorial newToOpenFoam OpenFOAM Running, Solving & CFD 2 July 14, 2011 10:50
motorBike tutorial and Scaling - New geometry used, scaled and now large velocity!!! scott OpenFOAM 1 July 29, 2010 05:09
