AMI with linear translation motion
Old   May 23, 2012, 09:11
Default AMI with linear translation motion
macti
macti is on a distinguished road
Hello everybody,
I'm trying to simulate a linear translation motion of a solid body with OpenFOAM 2.1.0, in a turbulent flow (in 3D). I would like to use the AMI tool, to avoid the constraint of the mesh deformation while the body's motion. But I have a problem: it seems that there aren't interpolations between the two AMI that I use, and it produces strong errors at the interface, on all fields (p, U, k...). Do you know if this utilisation of the AMI could work? And if not, do you have any suggestion to manage to solve my problem?
Thank you!!
PS: I have attached two pictures, the first one is a 2D view of the mesh (the solid body which has to move to the top of the duct is situated at the right of the obstacle), the inlet flow is at the left; the second one is a view of the non-interpolation problem...
macti is offline   Reply With Quote
Old   September 29, 2013, 06:58
stephane sanchi
openfoam_user is on a distinguished road
did you solved your problem ?
I would like to compute same kind of flow.
Best regards,
Stephane.
openfoam_user is offline   Reply With Quote
Old   June 27, 2017, 12:05
decibelle is on a distinguished road
I've also the same problem, someone have a solution?
thanks
decibelle is offline   Reply With Quote
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
solution diverges when linear upwind interpolation scheme is used subash OpenFOAM 0 May 29, 2010 02:23
translation motion Zxi Toh CFX 2 March 15, 2004 12:00
