OF 1.6-ext directMappedWall problem
Old   May 21, 2012, 13:57
Default OF 1.6-ext directMappedWall problem
Pekka is on a distinguished road
Hi Foamers,
The problem using chtMultiRegionSimpleFoam solver found on the OF version 1.6-ext-cf522b76968d (check out 26.04.2012). I ran old cht case which works fine using OF 1.6-ext-f3027b3161e4 (check out 08.11.2011) but does not work on newer OF. The calculation not started and it says that directMappedWall patch are use wrong sample region and patch. For example
HTML Code:
     topAir_to_bottomSolid
        type            directMappedWall;
        nFaces          70;
        startFace       14100;
        sampleMode      nearestPatchFace;
       sampleRegion    bottomSolid;                //correct sampleRegion, works old OF version
 //       sampleRegion    topAir;           //incorrect sampleRegion, works newer OF version but results are not correct
        samplePatch     bottomSolid_to_topAir;     //correct samplePatch, works old OF version
 //      samplePatch     topAir_to_bottomSolid;    //incorrect samplePatch, works newer OF version but results are not correct
        offset          (0 0 0);
when I changed the sample Region and Patch so that both are from the same region (incorrect) then newer version OF calculate but there is no temperature connection between patches?
Has the batch definition changed? What is a idea take a sample from the same patch in the directMappedWall?
Does anyone have experience with this?
BR/Pekka
Pekka is offline   Reply With Quote
Old   May 28, 2012, 01:57
I fix this problem which related to sampleRegion and samplePatch. I replace files:
src/finiteVolume/fields/fvPatchFields/derived/directMappedFixedValue/directMappedFixedValueFvPatchField.C
src/finiteVolume/fields/fvPatchFields/derived/directMappedFixedValue/directMappedFixedValueFvPatchField.H
src/meshTools/directMapped/directMappedPolyPatch/directMappedPolyPatch.C
src/meshTools/directMapped/directMappedPolyPatch/directMappedWallPolyPatch.C
from older OF versions and compile again.
I read from forum about the directMappedWall boundary condition and conclusion was that requires a conform mesh between regions, is it correct? Has anyone implemented a ggi interface to chtMultiRegion solver? Any ideas about this?
BR/Pekka
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
Solve single but higher order equation by OF 1.6 suffering Problem alundilong OpenFOAM Programming & Development 0 December 23, 2010 14:53
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
