continuity error
Old   May 4, 2012, 06:53
Default continuity error
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am running chtMultiRegionSimpleFoam and I get a continuity error.
At the 3rd time step, in fact, I get this message:
Time = 3
Solving for fluid region internal_air
DILUPBiCG:  Solving for Ux, Initial residual = 0.04808972, Final residual = 0.0007848449, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.05127225, Final residual = 0.0006552669, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.0729375, Final residual = 0.001066777, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.02877754, Final residual = 0.001333761, No Iterations 1
Min/max T:273 280.0333
GAMG:  Solving for p_rgh, Initial residual = 0.7510464, Final residual = 0.00749785, No Iterations 12
time step continuity errors : sum local = 0.1550988, global = 1.846758e-16, cumulative = -2.644312e-07
Min/max rho:1.241297 1.277639
Solving for fluid region external_air
DILUPBiCG:  Solving for Ux, Initial residual = 0.08944471, Final residual = 0.0008127495, No Iterations 1
DILUPBiCG:  Solving for Uy, Initial residual = 0.05704025, Final residual = 0.0005949483, No Iterations 1
DILUPBiCG:  Solving for Uz, Initial residual = 0.09658343, Final residual = 0.0007494813, No Iterations 1
DILUPBiCG:  Solving for h, Initial residual = 0.4380229, Final residual = 0.005028673, No Iterations 1
Min/max T:297.621 298.3227
--> FOAM FATAL ERROR:
Continuity error cannot be removed by adjusting the outflow.
Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow.
Total flux              : 1564.848
Specified mass inflow   : 0.01700355
Specified mass outflow  : 0.0167709
Adjustable mass outflow : 0
    From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p
    in file cfdTools/general/adjustPhi/adjustPhi.C at line 118.
FOAM exiting
It suggests to check the BC on the U field. I think that mine are properly set:
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      binary;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    wall-external_air-roof
        type            fixedValue;
        value           uniform (0 0 0);
    wall-door-external_air
        type            fixedValue;
    symmetry_1-external_air
        type            symmetryPlane;
    symmetry_2-external_air
        type            symmetryPlane;
    wall_back-external_air
        type            fixedValue;
    wall_front
        type            fixedValue;
    ceiling
        type            fixedValue;
    floor-external_air
        type            fixedValue;
    /*infinite_air_inlet
	type        fixedValue;
	value       uniform (0 0.05 0);
    infinite_air_outlet
	type        fixedValue;
    infinite_air_inlet
	type        flowRateInletVelocity;
	flowRate    constant 0.017;
    infinite_air_outlet
	type        zeroGradient;
The p file is the following:
FoamFile
    version     2.0;
    format      binary;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 100000;
boundaryField
        type            calculated;
        value           uniform 100000;
        type            calculated;
        type            symmetryPlane;
        type            symmetryPlane;
        type            calculated;
    wall_front
        type            calculated;
    ceiling
        type            calculated;
    floor-external_air
        type            calculated;
        type            calculated;
    infinite_air_inlet
        type            zeroGradient;
    infinite_air_outlet
        type            fixedValue;
Thanks for any help,
Samuele
samiam1000 is offline   Reply With Quote
Old   May 5, 2012, 15:47
niaz's Avatar
A_R
niaz is on a distinguished road
Dear Samiam
are there any outlet in your test case?
in U field you determine all parameters?
is it that?
niaz is offline   Reply With Quote
Old   May 7, 2012, 03:49
Samuele Z
Dear Niaz,
yeah, I have an outlet
    infinite_air_outlet
        type            fixedValue;
Also, I think that I have set everything properly, haven't I?
What's wrong, to you?
Thanks a lot,
Samuele
Old   May 7, 2012, 04:40
Christian Lucas
Chris Lucas is on a distinguished road
why are all BC of your p field of type calculated? I would say that they should be zeroGradient (for the walls).
Best Regards,
Christian
Chris Lucas is offline   Reply With Quote
Old   May 7, 2012, 04:43
Samuele Z
Let me try like that.
The point is that (even tough I recognize that those BC are probably incorrect) I have a very similar case with the same BC that runs.
Let me give a try, then I get back to you.
Thanks,
Samuele.
Old   May 7, 2012, 04:46
Samuele Z
I've just given a try and nothing changes. If you agree I can send you an email, attaching the case.
Do you agree?
Old   May 7, 2012, 07:55
niaz's Avatar
A_R
Originally Posted by samiam1000 View Post
Dear Niaz,
    infinite_air_outlet
        type            fixedValue;
Thanks a lot,
Samuele
Dear Samiam
you force your outlet to go at fixed value uniformly?
it is not correct
Old   May 8, 2012, 08:12
Eysteinn Helgason
eysteinn is on a distinguished road
Originally Posted by niaz View Post
Dear Samiam
it is not correct
Seems ok to me . . . . unless there is something specific with the cht solver.
You might try to change the outlet type for U to something like fluxCorrectedVelocity or inletOutlet instead of zeroGradient.
Also have you checked that your mesh has type: patch set for inlet and outlet in constant/polymesh/boundary and emtpy for your empty patches. . . . had that problem once after exporting my mesh from ansa or icem.
eysteinn is offline   Reply With Quote
Old   May 8, 2012, 09:27
Samuele Z
It's very strange: I created a new case and it now runs.
I can't und why, but everything is ok!
Thanks for help.
Samuele.
Old   May 9, 2012, 04:01
Adam Sitko
sitekss is on a distinguished road
Hi Foamers,
I think that samiam overdefined the model, especially the outlet. But I have similar problem in my case. I observe unexpected temperature rise when 'hot' air hit the outlet. My BC there p_rgh - fixedValue value 100000; U - zerogradient; p - calculated / zeroGradient; T - zeroGradient/ fixedValue. It's strange.
BR
Adam
sitekss is offline   Reply With Quote
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
CGNS lib and Fortran compiler manaliac Main CFD Forum 2 November 29, 2010 07:25
attach/detach (valve opening/closing) phsieh2005 OpenFOAM Running, Solving & CFD 2 March 21, 2009 06:18
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
user defined function cfduser CFX 0 April 29, 2006 11:58
