How to set prefcell/prefvalue
Old   May 3, 2012, 05:35
Default How to set prefcell/prefvalue
NGH
NGH
NGH is on a distinguished road
Hi
Im trying to set up an Openfoam case and got this fatal error, prefvalue/prefcell not set. Why is this so and how and where to set the value as I cant find this variable under 0, system directories? Thanks
NGH is offline   Reply With Quote
Old   May 3, 2012, 10:31
David Gaden
marupio is on a distinguished road
I believe it's in your system/fvSolution file, at the bottom usually. It's in a sub-heading that depends on the solver. If your solver uses the PISO algorithm, it'll be in the "PISO" heading. E.g.:
PISO
    nCorrectors     2;
    nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Porous region set braket FLUENT 4 November 18, 2010 03:09
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 13:44
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 03:24
Ibm java gcc rrr OpenFOAM Installation 2 December 30, 2005 05:18
