May 1, 2012, 07:31 |
Problem related to topology
ankur
Rep Power: 14 |
Hey
I am trying to mesh a rectangular tank with 5 pipes, but I am having the following problem with my blockMesh : /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-f802ff2d6c5a Exec : blockMesh Date : May 01 2012 Time : 15:27:17 Host : karya101.hbni.ac.in PID : 14790 Case : /home/usr0201/ankur_a/hotRoom nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/usr0201/ankur_a/hotRoom/constant/polyMesh/blockMeshDict" Creating blockCorners Creating curved edges Creating blocks --> FOAM Warning : From function bool Foam::blockMesh::blockLabelsOK(const label blockLabel, co nst pointField& points, const cellShape& blockShape) in file createTopology.C at line 67 block 31 point label 112 larger than 111 the largest defined point label Creating patches Cannot create mesh due to errors in topology, exiting ! From function blockMesh::createTopology(IOdictionary&) in file createTopology.C at line 376. FOAM exiting I am new to the openfoam so could not figure out the problem, can anyone please help me.. |
May 1, 2012, 09:02 |
Björn Windén
Location: National Maritime Research Institute, Tokyo, Japan
Rep Power: 14 |
Hi.
That means that you have defined 112 points in your vertex list (so the last one has the label 111) but in block 31 you have tried to access point number 113 (with label 112.) Remember that the first point/vertex is number 0 not number 1. //Björn |
May 2, 2012, 05:02 |
ankur
Rep Power: 14 |
hey thanks alot..it worked but now I am having a new error.. I just could not debug it..if somone know the solution please let me know..
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 1.6 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 1.6-f802ff2d6c5a Exec : blockMesh Date : May 02 2012 Time : 13:13:20 Host : karya101.hbni.ac.in PID : 28798 Case : /home/usr0201/ankur_a/hotRoom nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/usr0201/ankur_a/hotRoom/constant/polyMesh/blockMeshDict" Creating blockCorners Creating curved edges Creating blocks Creating patches Creating block mesh topology --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -1.17853e-06 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -7.07108e-06 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -9.46363e-06 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -0.000270357 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -0.000119752 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -0.000160068 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -0.00013991 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -0.00013991 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file createTopology.C at line 398 negative volume block : 25, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -2.24473e-05 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -2.33901e-05 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -4.72524e-05 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -2.29187e-05 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 129 zero or negative pyramid volume: -2.29187e-05 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file createTopology.C at line 398 negative volume block : 26, probably defined inside-out Default patch type set to empty face 10 in patch 0 does not have neighbour cell face: 4(30 31 87 86)#0 Foam::error:rintStack(Foam::Ostream&) in "/home/usr0201/ankur_a/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/usr0201/ankur_a/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::Ostream& Foam:perator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) in "/home/usr0201/ankur_a/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #3 Foam:olyMesh::facePatchFaceCells(Foam::List<Foam ::face> const&, Foam::List<Foam::List<int> > const&, Foam::List<Foam::List<Foam::face> > const&, int) const in "/home/usr0201/ankur_a/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #4 Foam:olyMesh:olyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<Foam::word> const&, Foam::word const&, Foam::word const&, Foam::List<Foam::word> const&, bool) in "/home/usr0201/ankur_a/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #5 Foam::blockMesh::createTopology(Foam::IOdictionary &) in "/home/usr0201/ankur_a/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #6 Foam::blockMesh::blockMesh(Foam::IOdictionary&) in "/home/usr0201/ankur_a/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #7 main in "/home/usr0201/ankur_a/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/blockMesh" #8 __libc_start_main in "/lib64/libc.so.6" #9 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 125. FOAM aborting Aborted |
May 2, 2012, 06:08 |
Björn Windén
Rep Power: 14 |
That probably means that you have defined a block inside out, have you read the description of how to arrange the vertices within a block? It is very important that the vertices come in the right order when defining the blocks and the patches.
http://www.openfoam.org/docs/user/blockMesh.php //Björn |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 20:42 |
Can I solve this problem by Fluent? | Kai_kc | FLUENT | 1 | October 27, 2010 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 20:13 |
FSI problem with topology of 3D beam via UDF | greg | FLUENT | 7 | July 17, 2006 06:32 |
problem related to mesh | naveen | CFX | 3 | March 25, 2006 09:47 |
