uniform Scalar,setFields
Old   April 23, 2012, 13:01
Default uniform Scalar,setFields
Jian Zhong
zxj160 is on a distinguished road
Dear foamers,
I want to define a uniform scalar (e.g alpha) with 0 in some region and 1 otherwise (may use setfields utility). Also, I just want to make these values unchanged when running the code. How to deal with that in the solver?
zxj160 is offline   Reply With Quote
Old   April 23, 2012, 14:29
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Are you trying to use this field as a source term? If you are running OF 2.1 you might be able to use the source term functionality:
http://www.openfoam.org/version2.1.0/numerics.php
mturcios777 is offline   Reply With Quote
Old   April 23, 2012, 14:54
Jian Zhong
YES. My current code is :
fvVectorMatrix UEqn
fvm::ddt(U)
+ fvm::div(phi, U)
+ turbulence->divDevReff(U)
alpha*gradP
I defined gradP as a vector and alpha as a scalar. I want to keep alpha uniform when running as follows:
defaultFieldValues
volScalarFieldValue alpha 0
regions
boxToCell
box (0 0 10) (30 10 50);
fieldValues
volScalarFieldValue alpha 1
Old   April 23, 2012, 15:12
Marco A. Turcios
Looks like what you have is right, so long as no transport equation is solved for alpha you're in business. Are you having trouble with the current approach as is?
Old   April 23, 2012, 15:16
Jian Zhong
The initial alpha is right. It seems that the next time step the value of alpha is 0. I just want to keep it as the initial value all the running time.
Old   April 25, 2012, 01:23
Yogesh Bapat
ybapat is on a distinguished road
You might try this function in fvMatrix.H which sets values in given cells.
//- Set solution in given cells to the specified values
template<template<class> class ListType>
void setValuesFromList
const labelUList& cells,
const ListType<Type>& values
ybapat is offline   Reply With Quote
Old   April 25, 2012, 12:52
Jian Zhong
Many thanks. Could you tell me more about how to use the function in the fvMatrix.H?
Old   April 26, 2012, 00:56
Yogesh Bapat
I think it takes list of cells in which you want to set values and list of values in those cells.
So you have to create list of cells in which you want to set value of alpha.
You have to call this function before solve function for matrix is called.
Regards,
-Yogesh
Old   April 26, 2012, 14:10
Jian Zhong
Hi Yogesh,
Thanks. I have solved the problem by changing the definition of alpha in the creatalpha.H file similar to 'p'.
Cheers,
Jian
solvers, uniform constant
Free jet simulation msarkar OpenFOAM Running, Solving & CFD 39 May 11, 2021 14:21
chtMultiRegionSimpleFoam javad814 OpenFOAM 1 September 26, 2011 14:30
Need help with boundary conditions: open to atmosphere Wolle OpenFOAM 2 April 11, 2011 08:32
rhoSimpleFoam claco OpenFOAM 7 April 20, 2010 05:32
RasInterFoam STRANGE RESULTS AT BOUNDARY kumar2 OpenFOAM Running, Solving & CFD 8 March 24, 2008 19:38
