May 3, 2015, 10:04 |
#21 |
Ashvin Chaudhari
Rep Power: 15 |
Hi Xianbei,
Sorry for my late reply. I just noticed it now. Sure, we have made some comparison between the two solvers: rk4+projection and pisoFoam. I would encourage you to look the following two papers in order to see/learn the differences between RK-4 method and the built-in second order time integration. 1) http://www.sciencedirect.com/science...45793014000334 2) http://www.sciencedirect.com/science...65997814001513 - Ashvin |
December 6, 2016, 08:12 |
#22 | |
Mukesh Adlak
Rep Power: 10 |
Hi ashvin, Can u help me to run dynamicLagrangian SGS model ? I run my case but facing following error : --> FOAM FATAL ERROR: incompatible dimensions for operation [flm[0 4 -5 0 0 0 0] ] + [flm[1 1 -5 0 0 0 0] ] From function checkMethod(const fvMatrix<Type>&, const fvMatrix<Type>&) in file /mnt/home/SW/CFDSupportFOAM3.0/OpenFOAM-3.0.x/src/finiteVolume/lnInclude/fvMatrix.C at line 1295. FOAM aborting #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::error::abort() at ??:? #2 void Foam::checkMethod<double>(Foam::fvMatrix<double> const&, Foam::fvMatrix<double> const&, char const*) at ??:? #3 Foam::tmp<Foam::fvMatrix<double> > Foam:perator+<double>(Foam::tmp<Foam::fvMatrix<d ouble> > const&, Foam::tmp<Foam::fvMatrix<double> > const&) at ??:? #4 Foam::LESModels::dynamicLagrangian<Foam::EddyDiffu sivity<Foam::ThermalDiffusivity<Foam::Compressible TurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:? #5 ? at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 ? at ??:? Aborted (core dumped) If u can help, it will be great for my work. |
September 28, 2017, 12:53 |
Validation of pressure-incremental projection scheme + dynLagrangian model
#23 |
Santiago Lopez Castano
Rep Power: 16 |
Hi guys,
I just saw your discussion and I wanted to put my 2 cents on the issue. For the last month I have developed a projection method similar (see Guermond&Shen) to that of Chaudhari for the incompressible N-S equations, and as validation I run the classic channel flows with different Re. The difference of my case with oodlesChannel (or channel365) is that I drive my flow using a certain pressure gradient, not by setting some flow. Additionally, with the risk of sparking a salty debate, its my opinion that whenever you run openFOAM without any turbulence model you should not call your results 'DNS' but more 'NO-MODEL LES'. This given the 2nd-order FV nature of the library itself, and the boundary conditions that you can impose. In fact, calling 'cyclic' boundary conditions 'periodic' carries a promise that the developers where well aware of and thus decided to call them as the former. In any case, you'll find attached the velocity profiles and RMS of channel flows run using Re_tau=171 and Re_tau=410. In both the dynamic lagrangian model of Meneveau was used. In general results seem decent. Last edited by Santiago; September 28, 2017 at 13:22. Reason: ChaudharI |
September 29, 2017, 05:16 |
#24 |
Albrecht vBoetticher
Rep Power: 17 |
Tahnk you, that really helps!
September 28, 2019, 12:24 |
#25 | |
Maximus Arelius
Rep Power: 9 |
I am trying to use the dynamic Lagrangian model of Meneveau(1996) for reacting flows, but somehow for me the flm and fmm values become unbounded at some later stage during the simulation and the Co shoots above 1 and time steps sturuggles to maintain the maxCo and crashes finally. This however is not to be the case with Smagorinksy model. I am using the IC of flm and fmm form Meneveau(1996) and BC as zero gradient. The flow a is free shear jet flow. I am using `backward` scheme time differencing and `linear` spatial discretisation schems with maxCo 0.35. The mesh is fully structured with max aspect ratio of 15 and max non-orthogonality of 18. It will be beneficial for the CFD community if you could kindly share the setup values i.e. IC, BC of flm and fmm and the fvSchmes for the dynLag case. Thanks
-- 🃏Maximus🃏 |
September 30, 2019, 05:48 |
#26 | |
Rep Power: 16 |
Another thing: The dynLagrangian Smagorinsky model implemented in OF (whichever version, fork, etc) is not consistent at the test filter level, thus the results obtained are not going to be "correct". I recently published an article discussing this issue: https://www.mdpi.com/2311-5521/4/3/171 Cheers, S PS.: Initial conditions for a channel flow? A TS wave (doesn't matter the dimensionality). Set-up? Gauss linear all the way. Time? Not Euler. |
October 3, 2019, 04:16 |
#27 | |
Maximus Arelius
Rep Power: 9 |
Thanks for the reply. 1.For my case, it is a jet flow with no walls. Hence I set the values to ZeroGradient. I hope it is correct? 2. The inlet BC for velocity is derived from a precursor pipe flow simulation. The IC for flm and fmm are based on Meneveau(1996) so that Cs=0.16 initially. 3. Time Scheme: backward Convection: U->linear, flm,fmm->limitedLinear 1.0. 4. fvSolution(flm,fmm)->PBiCG(DILU) Somehow, I feel that the setup is very unstable as it caused the fmm value to explode somewhere in between the simulation. Is there something incorrect? Thanks in advance!
-- 🃏Maximus🃏 |
October 3, 2019, 08:30 |
#28 | |
Rep Power: 16 |
November 18, 2019, 12:53 |
#29 | |
Maximus Arelius
Rep Power: 9 |
About the inconsistency you mentioned for the test filter, can't we use the Laplace test filter( or anisotropic filter) implemented in OF? I understand that the grid level filtering is implicit but for test filter may be specified explicitly as Simple/anisotropic/Laplace. Will it still not give "correct" the results as you have achieve in your article using a Laplace test filter?
-- 🃏Maximus🃏 |
November 18, 2019, 15:05 |
#30 | |
Rep Power: 16 |
les, validation |
LES and DES models for wind turbine | mohammad | Main CFD Forum | 6 | April 30, 2011 23:01 |
LES models: | Jonathan Lemay | CFX | 6 | March 3, 2008 07:51 |
LES flamelet models | Simon Newbond | Main CFD Forum | 1 | August 5, 2005 07:17 |
Numerical Implementation of LES Wall models | dragon | Main CFD Forum | 2 | March 14, 2005 01:53 |
Mixed models in LES | Pradeep | Main CFD Forum | 4 | March 28, 2003 05:56 |
