Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Can use turbulance model for laminar flow?
Old   October 13, 2024, 12:57
Default Can use turbulance model for laminar flow?
Choni is on a distinguished road
I'm solving the stationary non-compressible task so I use simpleFoam and compare the results with the experiment data. The number of Reynolds in my problem shows that a flow is a laminar. But, my pressure values are on average 65% of what they should be. So, I want to try the turbulence model. I have a question: is it correct to use the turbulence model, if the viscosity shows that flow is a laminar?
And can you please advise where I can find simple/simplified explanations/discussions of RAS and LES models?
Choni is offline   Reply With Quote
Old   November 7, 2024, 17:44
Domenico Lahaye
dlahaye is on a distinguished road
Run with turbulence model and verify that turbulent viscosity (mut) is small?
dlahaye is offline   Reply With Quote
Old   November 15, 2024, 06:10
M
AtoHM is on a distinguished road
Check out Aiden Wimshurst's Channel on youtube. It is an excelent resource for all sorts of cfd topics
https://www.youtube.com/@fluidmechanics101
AtoHM is offline   Reply With Quote
laminar flow in pipe, reynolds number 500, simple foam, turbulance
axial compressor mass flow convergence issue jyotir SU2 5 July 5, 2024 10:06
Model of air–steam flow with condensation into the volume and surface wall gartz89 ANSYS 1 February 19, 2022 07:52
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Baldwin-Lomax model in wall jet flow K.S.Chang Main CFD Forum 0 December 7, 2005 02:51
turbulance model J.subramani CFX 1 January 4, 2004 18:00
