Incident Radiation Intensity(G) wrong value with fireFoam |
May 2, 2023, 10:13 |
I am a new user of fireFoam (for 3-4 month) and I am trying to verify some results with basic cases of radiation. The case is the following : - An infinite (obtained usig symmetryPlane as boundary condition foar the side of the domain) hot plate at 2000K considered as a blackbody() - The rest of the space is at 200K(for limitation consideration according to JANAF tables) - The medium is non-participating (emission and absorption = 0) In this case the analytical result of G, the incident radiation intensity, is a constant and equal to 907.2kW/mē = Using the fvDOM radiation model on fireFoam solver to do the radiation simulation, the result obtained is a constant but equal to 1814.8kW/mē. So twice the result we should have. I Dont know where this difference comes from... Anyone have any idea? Thanks ! |
December 13, 2024, 04:43 |
Harshin Kamal Asok
Rep Power: 9 |
Hi Did you figure this out? If yes could you explain what happened?
December 13, 2024, 05:27 |
December 14, 2024, 05:34 |
Harshin Kamal Asok
Rep Power: 9 |
Thank you very much for the explanation.I found the magnitude G much higher that qr on solar radiation tutorial examples in openfoam. qr is about 1000 W/m^2 which makes sense but G is about 4 times that value. The surfaces involved in the simulation is mostly soil ground which is not very reflective. |
firefoam;radiation, fvdom, value of g |
UDF for DOM incident radiation ( ansys fluent ) | pouriyana | Fluent UDF and Scheme Programming | 0 | May 8, 2019 06:38 |
Surface integrals report: incident radiation | Novice | FLUENT | 3 | February 8, 2018 10:53 |
udf error | srihari | FLUENT | 1 | October 31, 2016 15:18 |
Monte Carlo Simulation: H-Energy is not convergating & high Incident Radiation | volleyHC | CFX | 5 | April 3, 2016 06:41 |
radiation temperature ,G(the incident radiation) | ymg | FLUENT | 0 | October 16, 2008 09:57 |
