Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Surface tension
Old   January 21, 2023, 13:47
Default Surface tension
Richard Samman
Richard_S is on a distinguished road
Hello everybody,
I set up cases with multiphaseInterFoam for simulative investigation of slot die coating processes.
In my cases I simulate the flow of two identical but immiscible pastes with air (see png-file; paste1 blue, paste2 grey, air red). Due the pastes are identical, the surface tension should be 0 N/m.
I observed that surface tensions close to 0 induce a blurred interface with waves (like the upper case of the png-file. The case beneath has a higher value of the surface tension).
Does anybody knows the reason for the formation of those waves? I assume the answer is hidden in equations that use the surface tension - can anybody help me?
Sincerely Richard
Richard_S is offline   Reply With Quote
Old   January 21, 2023, 21:06
Will Kernkamp
wkernkamp is on a distinguished road
1. It would be logical to see turbulent mixing in the flow, this will be suppressed by adding surface tension.
2. The waves in the interface seem connected to a rhythmic pattern on the lower boundary. This pattern also exist in the solution with surface tension.
wkernkamp is offline   Reply With Quote
Old   January 23, 2023, 11:29
Richard Samman
Thx for the answer!
1. I forgot to say that I only simulate a laminar flow.
2. The lower wall is in motion and moves rightwards. The rhythmic pattern you detected is entrained air. This pattern is unwanted and I suppressed this effect in a new case (see new picture "localSlip") with a special boundary condition.
I also added a pic with velocity U and pressure p.
However, the waves on the interface remain.
In my simulations, surface tensions of dimension 0.01 N/m or lower result in those waves.
With 0.1 N/m the waves vanish. (very high surface tension! ; water-air has 0.07 N/m !)
I don't understand this phenomena and appreciate every explanation.
Old   January 23, 2023, 17:14
Will Kernkamp
Could it be grid related. Try a 2x refined mesh and see if the waves become twice as small.
Shear layers are unstable in this way, but from you velocity magnitude plot it doesn't look like there is a velocity gradient at the interface (but hard to tell).
blurred interface, surface tension model
Solution not converging with Surface Tension modeling faizan356 Fluent Multiphase 0 July 28, 2021 03:53
Error in gmshToFoam on ESI v2106 siefer92 OpenFOAM Programming & Development 4 July 17, 2021 06:11
surface tension gradient using UDF; surface tension gradient as function of temperatu marimuthusundar Fluent UDF and Scheme Programming 0 June 21, 2012 05:48
surface tension gradient on a free surface Abrem FLUENT 1 April 30, 2006 04:41
surface tension model in EX26 Junhua Wu FLUENT 0 June 7, 2000 11:49
