December 12, 2022, 03:18 |
Drag coefficient shows non-realistic values
Hendrik
Rep Power: 13 |
Good Morning CFD Engineers!
We did a simulation of a C-shaped geometry (1.5m height x 4 m length) which faces an airstream with the open side of approx. 15 m/s. In various CFD-Simulations we always got a drag coefficient of approx. 0.8 while Wikipedia-tables shows 2.3 for open half pipe. Client points out, that the 2.3 is realistic from experimental experience. We did not see changes with different turbulence models or LES Simulation. There was only one simulation where we increase k significantly in the k-epsilon model. In this simulation we got a value of 1.2. Does anyone have an Iidea what we have to change to reach higher values? Cheers! |
January 13, 2023, 23:20 |
Will Kernkamp
Rep Power: 14 |
I would suspect your domain is not big enough or it has the wrong boundary conditions.
drag, turbulence models |
Lift and Drag at Transonic Speeds are Orders of Magnitude from realistic values | ssa44 | FLUENT | 0 | March 22, 2021 15:51 |
Drag Coefficient calculation for flow over a 2D Cylinder at High Reynodls Numbers | DanielBarreiro | CFX | 13 | February 26, 2019 09:40 |
Drag coefficient do not match of the experimental result | recep911234 | FLUENT | 5 | December 12, 2018 23:54 |
High drag coefficient Cd values | czhongrong | OpenFOAM Post-Processing | 0 | December 5, 2015 22:49 |
Strange values for Lift & Drag Coefficient | recnice | OpenFOAM Running, Solving & CFD | 3 | November 18, 2011 20:31 |
