August 22, 2022, 10:48 |
y plus for Realizable k-e
Alexander Yurishchev
Rep Power: 7 |
Hi all,
I am a bit confused. Is it ok to use 30<y+<300 for modeling with the Realizable k-e model? Or should I locate the first layer is viscous region (y+<5)? Thanks all, A. |
September 15, 2022, 06:58 |
Rep Power: 8 |
30<y+<300
this is the range for high-RE turbulence models, if you want to resolve y+<30 you should use a low-RE turbulence model. Realizable k-eps. is a high-RE model. choose your wall function accordingly. |
