Wrong mass flux for solid into fluid domain in icoFsiElasticNonLinUlSolidFoam solver |
September 23, 2019, 01:34 |
Emad Tandis
Rep Power: 16 |
Hello all,
I'm working on the tutorial problem for icoFsi solver, named "Hron Turek FSI". The icoFsiElasticNonLinUlSolidFoam gives good results for the movement of flag end. The problem is when you more delve into the solution files such as phi in each time step, you can see you have a non-zero mass flux for the moving wall of the plate into the fluid domain. However, the phi, which is relative mass flux, must be zero at wall around the fluid domain, even for moving wall. The question is: Is it normal to have a mass flux from moving wall into the domain of the fluid? Any comment is appreciated. |
September 23, 2019, 11:43 |
Herpes Free Engineer
Rep Power: 13 |
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 18:19 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
