Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Pressure drop error of laminar pipe flow with simpleFoam
Old   September 11, 2019, 13:39
Default Pressure drop error of laminar pipe flow with simpleFoam
Xiaolong Liu
xiaolong is on a distinguished road
Hello Foamers,
I am new to openfoam. I am trying to simulate a laminar pipe flow by using simpleFoam and compare the pressure drop with the analytical solution. However, I found a quite consistent about 11% pressure drop error by adjusting the inlet velocity (Re=500, 1000, 1500, 2000)
Below are the parameters I used for this simulation
Pipe length (L): 0.5m
Pipe diameter (D): 0.015m
Dynamic viscosity (mu): 8.9e-4 N/m-s
Density (rho): 997 kg/m^3
Max value of parabolic velocities:
(1) 5.96e-2 m/s(Re=500); (2) 1.19e-1 m/s (Re=1000); (3) 1.78e-1 m/s (Re=1500); (4) 2.38e-1 m/s (Re=2000).
Boundary conditions:
p:
Inlet: zeroGradient;
Outlet: fixedValue uniform 0;
Wall: zeroGradient;
U:
Inlet: parabolic velocity (I tried fixedvalue uniform inlet velocity as well without measuring in the entry length region, the same problem);
Outlet: zeroGradient;
Wall: fixedValue uniform (0 0 0);
I also compared simulation results with Fluent, as shown in the figure below:
https://www.dropbox.com/s/22xv8hlwuv...luent.png?dl=0
I have tried (1) refining the mesh in different levels; (2) adjusting the gradient scheme to leastsquares method; (3) importing the mesh developed in ANSYS for Fluent simulation. None of these can change the results.
Since this is a very simple case, I believe simpleFoam should be able to provide accurate prediction on the pressure drop. However, I just can not get it.
I really appreciate if anyone can help to point out what the problem is.
Please find my code in the following link:
https://www.dropbox.com/sh/3ow6w0cvx...LbEbgwH_a?dl=0
Thanks,
Xiaolong
Last edited by xiaolong; September 12, 2019 at 09:34. Reason: To make a statement more clear
xiaolong is offline   Reply With Quote
Old   September 12, 2019, 03:45
anonymous
simrego is on a distinguished road
Hi!
Sorry, I was wrong, but I can't delete the post.
simrego is offline   Reply With Quote
Old   September 12, 2019, 09:27
Xiaolong Liu
Hi simrego,
Thanks for your quick reply though.
Xiaolong
Old   September 16, 2019, 11:51
Xiaolong Liu
Just got pointed out by another foamer. I set wrong value of nu in transportproperties. Now they match.
Old   September 22, 2019, 06:07
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
Dear Xiaolong Liu,
Is there any chance for you to share your setup and results, so that OpenFOAM maintainers can use these as a showcase?
Kind regards,
HPE
HPE is offline   Reply With Quote
laminar pipe flow, pressure drop error, simplefoam
Using Darcy Pressure equation to verify ABAQUS CFD laminar flow analysis Chris1234 Main CFD Forum 0 April 30, 2019 11:04
lower pressure drop compared to experimental value in Two phase flow calculations. Ash Kot Fluent Multiphase 0 May 16, 2017 17:29
Orifice-Pipe Problem CFXMUFFIN CFX 3 July 16, 2015 19:57
pressure drop - pipe flow C.C Main CFD Forum 6 November 19, 2012 11:02
Pressure drop in laminar flow carno FLUENT 11 September 9, 2007 11:46
