Pradeepkumar Jagdale
Rep Power: 7 ![]() |
Has anyone tried running FSI-2 turek's benchmark problem on Open Foam?
I tried by changing u-max to 1.5m/s (i.e u_bar = 1 m/s for parabolic inflow) E for solid to 1.4x10^6 Pa But it did not run. The flag didn't move. Please can you suggest to me what more modifications must be done to run FSI 2 case? Thank you |
Density ratio is to be maintained 10 in FSI 2. So the density of Solid is 10000. This parameter is also needed for FSI 2 benchmarking.
foam extend 4.0, fsi 2, fsi-foam, turek |
Problem with restart in FSI unsteady simulation | david_mocholi | SU2 | 1 | June 24, 2023 06:06 |
Error for solving FSI problem by using fsiFoam, thanks. | liyanmiho | OpenFOAM Running, Solving & CFD | 2 | March 27, 2019 14:09 |
Two way Fsi Problem- Non linear problem | kmgraju | CFX | 4 | April 28, 2015 11:15 |
Defining contact regions in FSI problem.!!! | sreemvlk | ANSYS | 0 | June 12, 2014 00:33 |
divergent of a FSI problem | edooo0 | FLUENT | 0 | August 5, 2013 17:54 |
