Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
icoReactingMultiphaseInterFoam air on water stratified flow
Old   August 20, 2019, 14:31
Default icoReactingMultiphaseInterFoam air on water stratified flow
tonnykz is on a distinguished road
Hello everyone,
I am writing to take some suggestion on how to proceed with simulations.
The case I am investigating is stratified flow of air on water at small scales (1cmX0.1cmX0.1cm) in channel.
I have tried both:
a) uniform inlet and outlet. (top and bottom - walls).
b) separated inlet and outlet.
So my question is:
1)Is it fine to use separated inlet and outlet?
2)Is my case file correct, IC and BC specifically?
In the link provided you can find case file. As I can't upload archive weighting more than 193 kb.
https://drive.google.com/open?id=1sU...2vysT3d2En4Yiq
Any help is greatly appreciated!
Thanks,
Tonnykz
tonnykz is offline   Reply With Quote
interfoam, multiphase flow, stratified flow
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
Help Initializing open channel flow with air and water jvoi_boy Main CFD Forum 0 September 20, 2018 02:26
Can people model 2 phase fluid flow (air water) in 6 mm tubing? gaiatechnician Main CFD Forum 0 August 25, 2015 15:20
governing equations in air water flow ghazali Main CFD Forum 1 March 8, 2015 23:47
Water jet in confined hot air cross flow Jim Clancy FLUENT 0 November 24, 2007 17:14
