kOmegaSST - curvature correction - Rotating electrochemical systems |
April 3, 2019, 11:02 |
Alejandro
Rep Power: 12 |
Results of numerical calculations and their comparison with analytical expressions or experimental data under laminar and turbulent flow conditions are reported. It is predicted the transient and steady-state behaviour of mass-transfer coefficients and shear stresses in electrochemical reactors composed of rotating electrodes.
Computational fluid dynamics (CFD) simulations were performed for both the rotating disc electrode (RDE) and the rotating cylinder electrode (RCE) considering the laminar or Reynolds-Averaged Navier-Stokes (RANS) equations. In this last case, it was assumed the Shear Stress Transport (SST) k-ω turbulence model sensitised by a correction term that accounts for streamline curvature and rotation. The hydrodynamics, coupled to the averaged diffusion-convection equation under transient conditions, was solved using the open source software OpenFOAM. A good agreement was attained between simulations and experimental or analytical results. In both rotating systems, a steady-state can be reached with an oscillatory behaviour that can be periodic in the case of laminar flow; depending on the Schmidt number, the interelectrode gap and the hydrodynamics. Also, the uniformity of the mass-transfer coefficient is lost under some circumstances. Finally, the full numerical code and a tutorial on how to use it, in order to perform simulations for the RDE or RCE, are supplied. details: https://www.sciencedirect.com/scienc...8?dgcid=author |
kOmegaSST - Electrochemical systems | ancolli | OpenFOAM Verification & Validation | 0 | January 10, 2019 10:21 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 05:23 |
Production correction or curvature correction in the SST model | Ang | CFX | 2 | May 20, 2014 21:50 |
Turbulence Model Curvature Correction | Jorg | CFX | 0 | August 10, 2012 19:05 |
curvature correction term, material derivative of a tensor | volker | OpenFOAM Programming & Development | 7 | June 3, 2010 09:08 |
