Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
cavity using rhoCentralFoam
Old   July 5, 2015, 06:55
Default cavity using rhoCentralFoam
M. Sabouri
Moslem is on a distinguished road
Hi everyone,
I have simulated the square cavity problem using the rhoCentralFoam solver at the following conditions:
Re= 400, 1000
Ma~0.08.
I have also simulated it using the incompressible solver icoFoam and a Roe-solver.
while the results of incompressible icoFoam and those of compressible Roe-solver agree with Ghia et al(1982), the rhoCentralFoam solver gives a little different solution. The differences are more evident at the max/min of the (u-Y) and (v-X) profiles.
Have anyone performed such a simulation using the rhoCentralFoam solver?
Do you have any idea about the cause of such differences?
Regards.
Moslem is offline   Reply With Quote
cavity problem, ghia et al(1982), rhocentralfoam
Modify rhoCentralFoam: other equations of state fivos OpenFOAM Programming & Development 5 July 29, 2020 14:17
Urgent: Unsteady 3-D supersonic cavity flow Min-Sung Kang FLUENT 3 April 6, 2014 10:50
is there any parallel code for the famous Lid Driven Cavity flow? gholamghar Main CFD Forum 0 August 1, 2010 02:55
cavity in flat plate and drag prediction Far FLUENT 0 May 19, 2010 15:47
drag of flat plate with cavity Far FLUENT 0 May 18, 2010 05:57
