Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
Request for Lagrangian Particle Tracking Validation or Verification Paper
Old   May 3, 2015, 14:25
Default Request for Lagrangian Particle Tracking Validation or Verification Paper
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Hello All,
I have been trying to find a benchmark paper (Experimental or Numerical) for validation of Lagrangian Particle Tracking in OpenFOAM.
I have two general questions,
1) Lots of papers out there, have discussed about the particle concentration in a field and not the particle counts. As you know particle concentration is taken into consideration when one solves the eulerian model of the particles (Mass transport). However I don't know how to compare my lagrangian results with those of eulerian ones. How can I convert my lagrangian data (including particles position, size, etc) into eulerian concentration?
2) Is there any trustable lagrangian benchmark paper which I can use for validation!?
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   May 8, 2015, 18:08
Mojtaba.a's Avatar
Well I found the answer to the first question. This can be done easily using swak4Foam. Just need to add massFraction function of swak4Foam into the controlDict:
massFractionKinematic {
type expressionField;
autowrite true;
expression "lcsMassFraction(ParticleCloud)";
outputControl timeStep;
outputInterval 1;
fieldName ParticleCloudMassFraction;
Old   May 11, 2015, 07:11
Default Sample lagrangian particle(droplet) velocity
Tariq Ahmed
Tariq Ahmed is on a distinguished road
I would like to know how to sample the droplet velocities and size using swak4foam as I want to postprocess using Matlab
Tariq
Tariq Ahmed is offline   Reply With Quote
Old   May 11, 2015, 16:28
Mojtaba.a's Avatar
Originally Posted by Tariq Ahmed View Post
Tariq
Well Dear Tariq, I am not actually familiar with that, here I have just converted the lagrangian data into eulerian using swak4Foam.
Experts can help you in this field.
Hope you the best.
Old   May 12, 2015, 07:00
Default Lagrangian data
Tariq Ahmed
Thanks for replying. So do u know how to convert lagrangian particle velocity into eularian one like u have done for particle mass fraction? And also when I used the above code in control dict, my solver didnt create a postprocessing folder for saving the mass fraction values. i am using sprayfoam solver
tariq
Old   June 18, 2015, 17:03
Mojtaba.a's Avatar
Sorry for the late response.
Well I am not sure about the first question but about the second, There will be no postProcessing folder. Actually massFraction will be created individually for each time step. You can see massFraction as a new parameter in paraview while post-Processsing.
Old   May 23, 2016, 02:47
Ping Chang
chpjz0391 is on a distinguished road
autowrite true;
outputInterval 1;
Hey Mojtaba,
I met the same question as urs. I wanna calculate the mass concentration of particles(kg/m3) Can I use massFractionKinematic to achieve my goal. If I can ,could you plz post ur code in ur controlDic, thx.
chpjz0391 is offline   Reply With Quote
Particle tracking INTEGER limitation warning Peter023 FLUENT 0 June 24, 2013 04:59
DPM particle tracking sajeesh FLUENT 0 May 12, 2013 03:29
DPM particle tracking in stirred tank parisa- FLUENT 1 August 7, 2012 13:03
CFX-Pre problem, pls help!!! cth_yao CFX 0 February 17, 2012 01:52
DPM particle tracking parisa- Main CFD Forum 2 June 15, 2011 06:12
