Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Verification & Validation
pimpleFoam-rectangle
Old   May 7, 2014, 05:28
Default pimpleFoam-rectangle
Mattia
mattiaricci13 is on a distinguished road
Dear Foamers,
I am modeling the flow (wind) around a rectangle with aspect ratio 1:5 (Re=10E+4 based on "B", the rectangle edge along wind direction). I have performed 3-D LES Simulation ( 2 Millions of cells, Smagorinsky Model, not Dynamic) with OpenFOAM and I have compared results in terms of Cp average along the edge (in the flow direction) with both experimental and Fluent data. Fluent and OpenFoam use the same mesh, model and Reynolds.
I am not able to correctly reproduce the Cp (average) with OpenFoam. The image attached shows results obtained.
I have also performed a RANS simulations (k-omega model) and, again, i have obtained a Cp difference between OpenFoam and Fluent very similar to which showed in the .png attached.
I have also attached system and 0 folder.
Can someone help me please??
Thank you in advance.
mattiaricci13 is offline   Reply With Quote
external aerodynamics., pressure coefficients, rectangle
pimpleFoam initialization? TBERGE OpenFOAM Running, Solving & CFD 2 April 2, 2014 09:20
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
Understanding pimpleFoam convergence criterion Nucleophobe OpenFOAM Running, Solving & CFD 0 March 13, 2013 19:46
Differences simpleFoam vs. pimpleFoam / RASModel.H vs turbulenceModel.H uli OpenFOAM Programming & Development 7 January 26, 2013 16:01
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
