simpleFoam Validation in Urban Environment using AIJ guidelines (openCAE) |
October 22, 2013, 06:43 |
#21 | |
Masashi IMANO
Rep Power: 17 |
Hmm.. It seems that OF-2.1.0 does not have nutkAtmRoughWallFunction boundary condition. So I have changed nut wall function from nutkAtmRoughWallFunction to nutkWallFunction in branches/2.1/CaseA case. Please see changeset below and exclude "svn update" in that directory! http://www.opencae.jp/changeset/128/OpenFOAM-VandV-SIG Masashi Quote:
October 22, 2013, 12:19 |
#22 |
Alvin TS
Rep Power: 12 |
I have made the changes, but log.Toposet has errors too.While log.sample has FOAM warning, hope this is okay.
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-bd7367f93311 Exec : topoSet Date : Oct 23 2013 Time : 00:14:06 Host : "hpclogin2" PID : 6935 Case : /gpfs/home/tssim1/OpenCAE/AIJ-new2/OpenFOAM-VandV-SIG/AIJ-PWEAB/branches/2.1/CaseA nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Reading topoSetDict --> FOAM FATAL IO ERROR: cannot open file file: /gpfs/home/tssim1/OpenCAE/AIJ-new2/OpenFOAM-VandV-SIG/AIJ-PWEAB/branches/2.1/CaseA/system/topoSetDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87. FOAM exiting ================================================== = /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-bd7367f93311 Exec : sample -latestTime Date : Oct 23 2013 Time : 00:14:16 Host : "hpclogin2" PID : 7472 Case : /gpfs/home/tssim1/OpenCAE/AIJ-new2/OpenFOAM-VandV-SIG/AIJ-PWEAB/branches/2.1/CaseA nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 200 --> FOAM Warning : From function sampledSets::combineSampledSets(..) in file sampledSet/sampledSets/sampledSets.C at line 102 Sample set verx_-075 has zero points. --> FOAM Warning : From function sampledSets::combineSampledSets(..) in file sampledSet/sampledSets/sampledSets.C at line 102 Sample set verx_075 has zero points. --> FOAM Warning : From function sampledSets::combineSampledSets(..) in file sampledSet/sampledSets/sampledSets.C at line 102 Sample set verx_125 has zero points. --> FOAM Warning : From function sampledSets::combineSampledSets(..) in file sampledSet/sampledSets/sampledSets.C at line 102 Sample set verx_200 has zero points. --> FOAM Warning : From function sampledSets::combineSampledSets(..) in file sampledSet/sampledSets/sampledSets.C at line 102 Sample set verx_325 has zero points. Reading set description: verx_-075 verx_-050 verx_-025 verx_000 verx_050 verx_075 verx_125 verx_200 verx_325 Time = 200 End |
October 22, 2013, 12:31 |
#23 |
Alvin TS
Rep Power: 12 |
There should be a 'topoSetDict' file in the 'system' directory, should it?
October 23, 2013, 02:29 |
AIJ Test Case B
#24 | |
Alex Lee
Rep Power: 14 |
I could not resolve the problem using the above tips by Bruno. I did a ./Allrun in the kEpsilon folder and just to check out what is wrong with the script. Here is the error message during the simpleFoam run: /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.1-221db2718bbb Exec : simpleFoam Date : Oct 23 2013 Time : 14:19:00 Host : "judah-Ubuntu" PID : 23454 Case : /home/alex/OpenFOAM/CaseB-2.1/kEpsilon nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 --> FOAM FATAL ERROR: Cannot find file "points" in directory "polyMesh" in times 0 down to constant From function Time::findInstance(const fileName&, const word&, const IOobject::readOption, const word&) in file db/Time/findInstance.C at line 188. FOAM exiting ----------------------- |
October 23, 2013, 03:42 |
#25 | |
Masashi IMANO
Rep Power: 17 |
Hi Alvin,
I have added topoSetDict in trunk repository but I forgot to add it in branches repository, sorry. So I just added it now. http://www.opencae.jp/changeset/129/OpenFOAM-VandV-SIG Masashi |
October 23, 2013, 04:03 |
#26 | |
Masashi IMANO
Rep Power: 17 |
http://www.opencae.jp/changeset/130/OpenFOAM-VandV-SIG So please wait for a while until updating these cases for OF version 2.1.x. BTW as Bruno suggested, symbolic link files in CaseB/[RASModel] directories would not be checked out correctly if you check out on non *nix file system like NTFS or FAT. So checkout should be done on *nix file system or OS like Linux or Mac OS. All the Best, Masashi |
October 23, 2013, 09:10 |
#27 |
Alvin TS
Rep Power: 12 |
ありがとう, Masashi san
December 2, 2013, 01:08 |
#28 |
Alvin TS
Rep Power: 12 |
Hi Imano san,
Not sure if there is any update of the cases? |
December 16, 2013, 01:25 |
updates on cases on maintenance
#29 | |
Alvin TS
Rep Power: 12 |
January 2, 2014, 03:46 |
comparing timevaryingmappedfixedvalue and setdiscretefield
#30 |
Alvin TS
Rep Power: 12 |
Hi Masashi-san,
1) I would like to ask about your case A on the site http://www.opencae.jp/wiki/OpenFOAM-VandV-SIG/AIJ-PWEAB I looked through the '0' folder and it uses 'timevaryingmappedfixedvalue'. I thought you have used setdiscretefield utility since this case A does not use snappyhexmesh. Am I right to say that even for discretesetfield utility, one needs to specify the timevaryingmappedfixedvalue BC in the 0 folder? 2) Since you have done the case A using timevaryingmappedfixedvalue and setdiscretefield, is there any difference in the final results obtained? Regards Alvin |
July 23, 2014, 09:07 |
AIJ Test Cases OpenFoam Report
#31 |
Alex Lee
Rep Power: 14 |
Dear Imano san,
I am wondering have you ever compiled the AIJ validation results obtained using OpenFoam? If yes, could i have the privilege to obtain a copy of this report ? The purpose of this request is to enable me to bring to our building construction authority (BCA) and to convice them that OpenFoam results are as good as Fluent or CFX or Star CCM. Currently, they are so stiff neck about their decision on not letting people submitting OpenFoam results in building performance analysis submission. Your help is very much appreciated. Thank you. ALEX LEE |
buildings, simplefoam, urban wind, validation |
CFX problem in ubuntu (linux) | Vigneshramaero | CFX | 0 | July 13, 2012 10:22 |
CFX-Pre problem, pls help!!! | cth_yao | CFX | 0 | February 17, 2012 00:52 |
Porous jump in urban environment | samygero | FLUENT | 0 | February 14, 2011 18:26 |
