time step huge continuity errors, please take a look at my BCs
Old   April 15, 2012, 12:07
Default time step huge continuity errors, please take a look at my BCs
Mihai Pruna
mihaipruna is on a distinguished road
I'm using simplefoam trying to solve a simple case of pressure driven flow through a duct shaped like an s.
i got some results when i set the inlet velocity to 0, but i understand that is not the right way to do it and that it should be set as i set it below,which crashes.
p:
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.000000;
boundaryField
inletXmin
type freestreamPressure;
freestreamValue 0.000000;
outletXmax
type fixedValue;
value $internalField;
bottomYmin
topYmax
leftZmin
type symmetryPlane;
rightZmax
vol1face1
type zeroGradient;
vol1face2
type zeroGradient;
vol2face1
type fixedValue;
value uniform 100000;
vol3face1
type fixedValue;
u:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
#include "include/initialConditions"
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0.000000 0.000000 0.000000);
boundaryField
inletXmin
type freestream;
freestreamValue uniform (0.000000 0.000000 0.000000);
outletXmax
type inletOutlet;
inletValue $internalField;
bottomYmin
type freestream;
topYmax
type freestream;
rightZmax
type freestream;
leftZmin
type symmetryPlane;
vol1face1
type fixedValue;
value uniform (0 0 0);
vol1face2
type fixedValue;
vol2face1
type pressureInletVelocity;
vol3face1
type inletOutlet;
error:
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 void Foam::vtkSurfaceWriter::writeData<double>(Foam::Os tream&, Foam::Field<double> const&) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so"
#4 void Foam::vtkSurfaceWriter::writeTemplate<double>(Foam ::fileName const&, Foam::fileName const&, Foam::Field<Foam::Vector<double> > const&, Foam::List<Foam::face> const&, Foam::word const&, Foam::Field<double> const&, bool, bool) const in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so"
#5 void Foam::sampledSurfaces::sampleAndWrite<double>(Foam ::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so"
#6 void Foam::sampledSurfaces::sampleAndWrite<double>(Foam ::sampledSurfaces::fieldGroup<double>&) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so"
#7 Foam::sampledSurfaces::write() in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so"
#8 Foam::OutputFilterFunctionObject<Foam::sampledSurf aces>::execute(bool) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libsampling.so"
#9 Foam::functionObjectList::execute(bool) in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#10 Foam::Time::run() const in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#11 Foam::Time::loop() in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#12 Foam::simpleControl::loop() in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#13
in "/home/cadnexus/OpenFOAM/OpenFOAM-2.1.0/platforms/linux64GccDPOpt/bin/simpleFoam"
#14 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#15
Floating point exception
Mihai Pruna's Bio
mihaipruna is offline   Reply With Quote
Old   April 15, 2012, 19:15
Mihai Pruna
Ok, with a finer mesh it's better, no crashes
Time = 10
smoothSolver: Solving for Ux, Initial residual = 0.007497, Final residual = 0.000191026, No Iterations 2
smoothSolver: Solving for Uy, Initial residual = 0.00780401, Final residual = 0.000205816, No Iterations 2
smoothSolver: Solving for Uz, Initial residual = 0.00731843, Final residual = 0.000192019, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0264498, Final residual = 0.0025477, No Iterations 2
time step continuity errors : sum local = 4868.62, global = -409.19, cumulative = -31928.9
smoothSolver: Solving for omega, Initial residual = 0.0062248, Final residual = 0.000119997, No Iterations 2
smoothSolver: Solving for k, Initial residual = 0.014408, Final residual = 0.00032159, No Iterations 2
ExecutionTime = 2315.79 s ClockTime = 2320 s
Mihai Pruna's Bio
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 16:24
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
