8x icoFoam speed up with Cufflink CUDA solver library
Like Tree5Likes
Old   November 6, 2012, 06:56
atg
Karl
atg is on a distinguished road
You don't need cufflink to demonstrate this drop in performance with multiple GPUs.
Just fire up the .nbody simulation on your 2050, note the flops in the lower left corner, and then try it with two GPUs. When I do that with a 2090, the 2090 always beats the 2090 plus Quadro600, by a significant margin. I think it is down to the overhead associated with communicating back and forth to the CPU. Newer versions of CUDA and the Kepler thing are supposed to alleviate this to some degree as far as I know, which admittedly isn't very far!
Good Luck, and thanks for posting.
atg is offline   Reply With Quote
Old   November 6, 2012, 12:24
alquimista is on a distinguished road
agt I agree with the presence of a bottleneck but it must be largely compesated by the fact to use two GPUs. I'll test the .nbdoy simulation in systems with two Tesla 2050 and two GTX 690.
alquimista is offline   Reply With Quote
Old   November 6, 2012, 12:37
Checking the post again I note that you are using two differents kinds of GPU cards, in that case the Quadro600 is slowing down the system and the 2090 must wait for the Quadro600 to finish its task. So in that case there are no benefit.
I just have run the nbdoy with one 690 and with two 690 and the results are:
1 device: 903.968 single-precision GFLOP/s at 20 flops per interaction
2 devices: 1649.659 single-precision GFLOP/s at 20 flops per interaction
So its reasonable and the proper use of several GPUs justified. I would expect similar behavior in cufflink.
Does it metter to increase RAM for solver speed?? raima Main CFD Forum 1 February 28, 2008 11:47
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
CFX 5.5 Roued CFX 1 October 2, 2001 17:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 17:25
i wanna speed up my solver! Maciej Matyka Main CFD Forum 8 November 28, 2000 14:52
