twoPhaseEulerFoam settling velocity of a dilute suspension
Old   April 10, 2012, 08:54
Default twoPhaseEulerFoam settling velocity of a dilute suspension
otm
otm is on a distinguished road
Hello world!
I have set up a very simple case for the twoPhaseEulerFoam solver (OF-2.1.x). I want to run the very basic case of gravitational settling of a dilute (alpha<1%) suspension of small particles (density=1050 kg/m^3, diameter=100 µm) in a continous viscous (55 cSt, density 840 kg/m^3) fluid. However, I can't reproduce the expected settling velocity (2.5e-5 m/s). I would expect the particles to instantly get the correct settling velocity, but instead I see a too small but continously increasing settling velocity.
What I expect to see is something like what you can see in a settling experiment in e.g. a test tube, where you get (after some time) from the top down: clean (particle free) contionus phase, an interface moving downwards (direction of gravity) with the settling velocity of the particle phase, suspension of particles with constant=initial concentration, settled particles with high concentration (sludge) at the bottom.
About my case:simpleSettling.gz
I tweaked the "bed" tutorial. Made it 1D. Changed the *properties files as approproiate. No turbulence modelling should be necessary for this case, so I tuned it off. I have tried to turn of packing limiters and played with different BS:s but I can't reproduce the correct settling behaviour.
I would be glad if someone could explain how I should change my setup in order to get the expected result.
BR
Olle
otm is offline   Reply With Quote
settling, twophaseeulerfoam
help with UDF for contact angle based on contact line velocity gandesk Fluent UDF and Scheme Programming 14 October 29, 2012 14:58
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
Velocity Under-relaxation in SIMPLE type methods Matt U. Main CFD Forum 6 July 4, 2005 06:29
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
Convection velocity of Coherent structures Jongdae Kim Main CFD Forum 3 February 5, 2002 05:04
