April 3, 2012, 15:27 |
decomposeParDict errors when deleted
Mihai Pruna
Rep Power: 16 |
I'm not running my case in parallel, why does my meshing crash when I erased the file?
Mihai Pruna's Bio |
April 3, 2012, 15:44 |
Don't know why but sHM checks that file anyway so you need to leave that where it is.
April 4, 2012, 05:48 |
Rep Power: 14 |
Can you copy your error message here ?
April 4, 2012, 06:01 |
--> FOAM FATAL IO ERROR: cannot open file file: /home/ubuntu/Desktop/condivisa/8_cilindro/system/decomposeParDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 87. FOAM exiting This is mine, that is what you get when you do not have any decomposeParDict within you system folder. |
April 4, 2012, 08:45 |
Bernhard
Rep Power: 22 |
Which utility are you trying to run here?
April 4, 2012, 08:57 |
sappyHexMesh
April 4, 2012, 10:08 |
Mihai Pruna
Rep Power: 16 |
could this in any way be related to my other post where I stated that you cannot have more than two SHM instances running at the same time?
Mihai Pruna's Bio |
April 5, 2012, 12:54 |
Alberto Passalacqua
Rep Power: 36 |
This is just because snappyHexMesh meshes on multiple processors/cores.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. Last edited by alberto; April 5, 2012 at 12:56. Reason: typo |
April 5, 2012, 14:07 |
#9 |
Mihai Pruna
Rep Power: 16 |
I see...does that apply to solvers as well?
Mihai Pruna's Bio |
April 5, 2012, 15:31 |
#10 |
Alberto Passalacqua
Rep Power: 36 |
No. Solvers and other utilities in general do not require a decomposeParDict.
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
