Simulation of a low-speed fan
Old   March 23, 2012, 11:12
Default Simulation of a low-speed fan
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi all,
I'm simulating a low speed fan at idle speed. I'm getting divergence and very high values for U, p and turbulence. I have 15M cells, but only 5 layer in the BL. I think it can be problematic, however the CFX simulation works pretty good. I'm using the MRFSimpleFoam, kOmegaSST modelling. Here are my BC's:
initial conditions:
flowVelocity         (0 0 0);
pressure             0.0;
turbulentKE          0.1;
turbulentOmega       10;
turbulentEpsilon     0.001;
omega                 230.3834; //target omega angular velocity in rad/s
#inputMode           merge
inlet Pressure
type         totalPressure;
p0        uniform 0;
U        U;
phi        phi;
rho        none;
psi        none;
gamma        1;
value        uniform 0;
inlet U
    type         pressureInletOutletVelocity;    //for use with total pressure inlet BC
    value        uniform (0 0 0);
inlet K
type        turbulentIntensityKineticEnergyInlet;
intensity    0.05;    //low intensity 5%
U        U;
phi        phi;
value        $internalField;
inlet omega
type            turbulentMixingLengthFrequencyInlet;
mixingLength        0.01;
phi            phi;
k            k;
outlet P
       type            fixedValue;
        value           uniform 0;
outlet U
    type        inletOutlet;        //for use with totalPressure BC
    inletValue    uniform (0 0 0);
The walls have zeroGradient types for turbulence and pressure, and fixedValue uniform (0 0 0) for U.
fvSchemes
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         cellLimited Gauss linear 1;
divSchemes
    default          Gauss upwind;
    div(phi,U)       Gauss upwind;
    div(phi,k)       Gauss upwind;
    div(phi,omega)   Gauss upwind;
    div(phi,epsilon)  Gauss upwind;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         Gauss linear corrected;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DomegaEff,omega) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(1,p) Gauss linear corrected;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
fvSolution
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver                  GAMG;
        tolerance           1e-8;
        relTol              1e-4;
        smoother            GaussSeidel;
    nPreSweeps           0;
        nPostSweeps          2;
        cacheAgglomeration     true;
        nCellsInCoarsestLevel     10000;
        agglomerator        faceAreaPair;
        mergeLevels         1;
        maxIter             20;
//parameters for k-omega model
    U
        solver          smoothSolver;
    nPreSweeps       0;
        nPostSweeps      2;
        tolerance        1e-7;
        relTol           0;
        minIter        1;
        maxIter         5;
    k
        $U;
    tolerance    1e-08;
    relTol        0;
    minIter        1;
//    maxIter        3;
    omega
        $U;
    tolerance    1e-10;
    relTol        0;
    minIter        1;
//    maxIter        3;
    epsilon
        $U;
    tolerance    1e-12;
    relTol        0;
    minIter        1;
//    maxIter        3;
SIMPLE
    nNonOrthogonalCorrectors 5;        //because the mesh is highly not orthogonal. maximum 20, 0 is cartesian hexahedral!
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-5;
        U               1e-5;
        "(k|epsilon|omega)" 1e-5;
potentialFlow
nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.3;
    equations
        U   0.4;
    k   0.4;
    omega   0.4;
Picture is taken at the 10th step. Velocity magnitude using logarithmic scaling! Interpolation of the fields turned off. Mesh is fine enough.
I've also tried the case using simpleFoam, so without rotation and using flowRate inlet of 1% of the operating one.
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
Jet fan and Tunnel simulation ahlo7 CFX 9 November 13, 2019 05:54
Simulation of Fan in Open Atmoshphere shraman_goswami CFX 2 April 23, 2009 06:35
low speed compressible flow lily CFX 2 November 16, 2005 06:15
Advice-bc for low speed airfoil Vincent FLUENT 11 May 4, 2005 03:18
Multicomponent fluid Andrea CFX 2 October 11, 2004 06:12
