March 20, 2012, 23:09 |
Discretization Error vs Residual Error?
Daniel
Rep Power: 17 |
Hello all,
I just ran a sensitivity study on my case to see if I could improve my accuracy by using SFCD (2nd order scheme for convection terms) vs linearUpwind (1st order accurate). All else being equal, the SFCD case had a p-residual of 5e-1 and the linearUpwind case had a p-residual of 10e-3. I expected better accuracy from the 2nd order accurate case, but the residuals appear to show that was not the case. I am running simpleFoam on a 2D airfoil. Could anyone please suggest why the residual is higher for the 2nd order scheme? More strange behaviour: the SFCD took LESS time to execute the case, and resulted in values of Cd and Cm that were farther from the experimental data than the upwind scheme. I expected different. Can anyone explain this? Thanks, Dan |
March 21, 2012, 03:49 |
Anton Kidess
Rep Power: 30 |
I always thought linearUpwind is 2nd order upwind. Is plain "upwind" what you were intending to compare to?
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
March 26, 2012, 21:05 |
Daniel
Rep Power: 17 |
Hello Anton,
Thanks for finding my error, I appreciate it. Regards, Dan |
problem with Min/max rho | tH3f0rC3 | OpenFOAM | 8 | July 31, 2019 10:48 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 10:20 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 13:30 |
Unknown error | sivakumar | OpenFOAM Pre-Processing | 9 | September 9, 2008 13:53 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
