fvSchemes, Fina residual tolerance not working
Old   March 17, 2012, 10:55
Default fvSchemes, Fina residual tolerance not working
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
Hi all,
if I set the final residual tolerances, finally the solver doesn't reach the prescribed level. However, if I adjust the tolerance/reltol in the simple U/p etc. it can reach whatever I want. Is it a bug maybe?
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    pcorr
        solver          GAMG;
        tolerance       1e-2;
        relTol          0;
        smoother        DICGaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10000;
        agglomerator    faceAreaPair;
        mergeLevels     1;
        maxIter         10;
    p
        $pcorr;
        tolerance       1e-5;
        relTol          0.01;
    pFinal
        $p;
        tolerance       1e-8;
        relTol          0;
//parameters for k-omega model
    U
        solver          GAMG;
        smoother        DILUGaussSeidel;
    nPreSweeps       0;
        nPostSweeps      2;
        tolerance        1e-4;
        relTol           0;
        mergeLevels     1;
        maxIter         5;
    k
        solver          GAMG;
    nPreSweeps       0;
        nPostSweeps      2;
        tolerance        1e-4;
        relTol           0;
        mergeLevels     1;
        maxIter         5;
    omega
        solver          GAMG;
    nPreSweeps       0;
        nPostSweeps      2;
        tolerance        1e-4;
        relTol           0;
        mergeLevels     1;
        maxIter         5;
    "(U|k|omega)Final"
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-8;
        relTol          0;
SIMPLE
    nNonOrthogonalCorrectors 5;        //because the mesh is highly not orthogonal. maximum 20, 0 is cartesian hexahedral!
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-4;
        U               1e-4;
        "(k|epsilon|omega)" 1e-4;
potentialFlow
nNonOrthogonalCorrectors 10;
relaxationFactors
    fields
        p               0.3;
    equations
        U   0.7;
    k   0.5;
    omega   0.5;
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
Old   March 17, 2012, 17:26
David Gaden
marupio is on a distinguished road
Try prescribing something nonesensical in pFinal to see if it's actually even reading it. e.g. tolerance banana;
Follow me on twitter @DavidGaden
marupio is offline   Reply With Quote
Old   March 18, 2012, 21:21
Alberto Passalacqua
I see where your confusion can come from. The SIMPLE algorithm does not have any "final" iteration, so the pFinal entry won't be read. The "Final" entries are only used in solvers based on the PIMPLE algorithm, where indeed each integration (time or pseudo-time) step has more than one iteration. In short, the linear solver will give you the final residual you require in "p".
Also, please note that if tolerance is too small, the linear solver will stop at 1000 iterations by default (you can change this value). If you set a high tolerance (say 1.0e-2), the solver will stop at the first iteration below that value, so it would not surprise me if that would be smaller (say something like 0.004).
P.S. I am not so sure it's convenient to use GAMG on anything but p. For steady-state solutions, smoothSolver seems to work better for me.
Best,
Alberto Passalacqua
Old   March 20, 2012, 04:26
Attesz's Avatar
Attesz
Alberto, thanks for your comments. Indeed, I didn't see any pFinal nor GAMG for U in tutorial MRFSimpleFoam cases and on the Wiki.
Have a nice day,
Attila
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
